Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
lowering my CR-V
Old Dec 29, 2006 | 08:24 PM
andregarrucho's Avatar
Default need some help on lowering my CR-V
What's the best parts I could use to lower my '97 CR-V? All I could find online is the Eibach springs and the Skunk2 Coil Overs. Is there a coil over set i could use so i could just replace the original shocks with and slap the new one in? I'm thinkin' about droppin' up to 3 inches similar to this one http://www.superstreetonline.c...ports/
Would anybody know the parts used on this cr-v?
Modified by andregarrucho at 9:22 PM 1/1/2007
Old Jan 4, 2007 | 06:43 AM
crvpimpin's Avatar
Default Re: need some help on lowering my CR-V (andregarrucho)
i dropped mine with skunk2 coilovers and koni yellow adj shocks
it gets realy low and still has a bearable ride
the front goes about 2in lower still and the rear has about 1 in lower left
Old Jan 4, 2007 | 06:44 AM
crvpimpin's Avatar
Default Re: need some help on lowering my CR-V (crvpimpin)
thoses are 18's btw
Old Jan 4, 2007 | 08:41 AM
wow! that's exactly how i'd like my cr-v to look like. but i have 17's on mine. thanks for the reply. how's the ride though? i also found out that ksport has coilover system for 97 cr-v but are kinda pricey. any suggestions on what i should get? now i'm thinking skunk coilovers and the koni struts or the set of ksport coilover system for the cr-v...
Old Jan 4, 2007 | 08:55 AM
crvpimpin's Avatar
i dont know anything about the ksport
the ride isnt bad a little rouhg over big bumps other wise its not that bad and i keep my shocks set to stiff
and my wife drives it and doesnt mind it so it couldnt be that bad
i would get a camber kit though
i have the ingals front kit
i got it and the koni's from tire rack
Old Jan 4, 2007 | 09:29 AM
justint's Avatar
How the F do you keep your NBP paint looking so good?
Old Jan 4, 2007 | 10:10 AM
Default Re: need some help on lowering my CR-V (justint)
you talking about the black or the red cr-v? the paint job is actually faded on mine. it was just newly waxed. i use Meguiar's all the way for my auto and motorcycle detailing needs.
aarzate01
20
Feb 24, 2014 06:20 AM
phoshyzzle
Jan 2, 2008 04:23 AM
97hatchb16
Suspension & Brakes
Nov 25, 2006 09:02 PM
KnuckleZ
Dec 30, 2005 08:03 AM
sohctodohc
Oct 6, 2004 11:59 AM
