ZC swap problems...help!
Old Dec 29, 2006 | 08:08 PM
White91EF's Avatar
Default ZC swap problems...help!
ok so i just did my first DOHC ZC swap...started right up. now the problem im having is when i start to give it gas it sort of bogs out then goes... also sometimes i hear a loud pop from the intake when i get on it. checked wires they are good have spark in all cylinders. also it runs ok until it warms up then it starts to get really hot. i noticed the upper rad hose gets hot but the bottom one doesnt. just replaced the thermostat no difference, the water pump was good in the old car so im assuming it is good, i dont see any leaks. also once the car is warmed up i see a lot of white smoke coming from the exhaust, but that might be cuz its about 15 degrees out side i dont know... anyone have any ideas?
Old Dec 29, 2006 | 08:20 PM
91H4hatch's Avatar
any codes?
Old Dec 29, 2006 | 08:44 PM
White91EF's Avatar
Default Re: (91H4hatch)
no codes at all...
Modified by White91EF at 1:13 AM 12/30/2006
Old Dec 29, 2006 | 09:03 PM
2slow4stock's Avatar
not like that. you still would be running fuel regardless.
Old Dec 29, 2006 | 09:04 PM
ohh yeah, check the timing. might be off.
Old Dec 29, 2006 | 09:48 PM
White91EF's Avatar
Default Re: (2slow4stock)
ok, does this sound right?
water pump goes bad..causing head gasket to leak a small amount of coolant which i see coming out of the exhaust. that would explain the cold lower hose and the white smoke.. am i right?
Old Dec 29, 2006 | 09:56 PM
JDM_PROJECTS's Avatar
Default Re: ZC swap problems...help! (White91EF)
check all the conections in the back of the manifold i had the same problem their like 2 cables that have the same style plug so they can be easily interchanged without nowing
Old Dec 29, 2006 | 10:18 PM
White91EF's Avatar
Default Re: ZC swap problems...help! (JDM_PROJECTS)
could i maybe have a cracked head? it doesnt start smoking til the car starts to overheat..
Old Dec 29, 2006 | 10:39 PM
blk crx's Avatar
i say timing thats the only thing i think would cause popping from the intake
Old Dec 29, 2006 | 10:44 PM
White91EF's Avatar
Default Re: ZC swap problems...help! (blk crx)
ok so im pretty sure the timing is off.... but as far as the smoking, overheating, etc.... what do you think?
Modified by White91EF at 1:15 AM 12/30/2006
Old Dec 30, 2006 | 12:12 AM
White91EF's Avatar
bump
Old Dec 30, 2006 | 01:26 AM
DarkSol97's Avatar
is there any white milky substance on the bottom of your oil cap? If so, you could be looking at a blown head gasket?
Old Dec 30, 2006 | 05:42 AM
White91EF's Avatar
Default Re: ZC swap problems...help! (DarkSol97)
nope not seeing anything like that oil and coolant both look clean, thats why i think it might be a cracked head, when it gets hot it expands making the crack expand and letting coolant burn off maybe?
Old Dec 30, 2006 | 05:56 AM
rice a roni's Avatar
timing dude...i was playing with my dizzy one time and i put it back too far advanced and it pops when you get on the gas...then i retarded the ignition timing a bit and it stopped...play with your dizzy.
Nooch
Jun 8, 2010 05:25 PM
JDMefHATCH7
Nov 29, 2009 01:29 PM
alupso
23
Feb 2, 2009 05:27 PM
freshly boosted DOHC ZC
Nov 25, 2006 05:45 PM
integ u
24
Mar 11, 2004 05:01 PM
