Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Turbocharger vs. Supercharger
Old Dec 29, 2006 | 05:28 PM
tony369's Avatar
Default Turbocharger vs. Supercharger
whats up...i dont currently own a civic but i am looking to buy an 07 civic si sedan and obviously im gonna put some upgrades on it and i pretty much have everything figured out but one thing...turbocharger or supercharger...wat do u guys think and wat type of turbo or supercharger
Old Dec 29, 2006 | 05:30 PM
L-Dawg's Avatar
Default Re: Turbocharger vs. Supercharger (tony369)
AJP turbo
Old Dec 29, 2006 | 05:34 PM
tony369's Avatar
y not the supercharger
Old Dec 29, 2006 | 05:36 PM
HondaF1Fanatic's Avatar
Turbo's are the best way to go if you want to get the highest volumetric efficiency but there are very few CARB exempt turbo kits because a turbocharger adds something in the exhaust stream that makes emissions tuning harder. If you want to comply with emissions I would get a supercharger, if the biggest gains are your goal I would get a turbo.
Jon
Old Dec 29, 2006 | 05:38 PM
tony369's Avatar
where can i find this AJP turbo kit
Old Dec 29, 2006 | 05:40 PM
Default Re: (tony369)
http://www.ajperformance.com/
Jon
Old Dec 29, 2006 | 06:18 PM
Nighthawk R18's Avatar
Default Re: (HondaF1Fanatic)
there's also a Comptech Supercharger
http://www.comptechusa.com/sto...6.pdf
haha ionno but those are the instructions...hope it helps
Old Dec 29, 2006 | 08:35 PM
Striker_1818's Avatar
Default Re: (Nighthawk R18)
s/c = adds more torque and a decent amount of hp to the car
t/c = adds lots of hp and a not so great amount of torque to the car
or maybe im wrong?
Old Dec 29, 2006 | 08:44 PM
WILD_WILL's Avatar
Default Re: (Striker_1818)
S/C= That funny whining sound it makes some people like it some don't.
T/C= It makes all the right sounds pure SEX !
Old Dec 29, 2006 | 10:04 PM
originalg00kster's Avatar
Default Re: (WILD_WILL)
SC = more low end...correct me if im wrong? out of the whole torquey wise...mid range power...
turbo = get to higher speed faster...much more hp gained...more top end.
Old Dec 29, 2006 | 10:10 PM
Default Re: (originalg00kster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by originalg00kster &raquo;</TD></TR><TR><TD CLASS="quote">SC = more low end...correct me if im wrong? out of the whole torquey wise...mid range power...
turbo = get to higher speed faster...much more hp gained...more top end.</TD></TR></TABLE>
yeah basically a s/c will give you boost at low rpms while a turbo will give you boost at higher rpms.
Exact samething you just said but worded differently =D
Old Dec 29, 2006 | 10:56 PM
Halcyon819's Avatar
go SC for daily driveability. i'm going to do that prob. in a year or so. i wanna run down my warranty first.
Old Dec 30, 2006 | 02:44 AM
Demonis's Avatar
S/C = Power that is on all the time, but lower gains.
T/C = Has to spool, but once it does...
Old Dec 30, 2006 | 07:28 AM
C Squared's Avatar
Default Re: (Demonis)
Turbo is powered by your exhaust gases but has more potential as the power increases exponentially.
A supercharger runs directly off the spinning of your engine, so the power is consistent and delivered immediatly.
Depends on what you want.
My old GSR had a Drag kit and it was pretty nice, but with my Si I plan on getting the Comptech supercharger. Just more fun for daily driving to me.
Old Dec 30, 2006 | 07:59 AM
RICO_'s Avatar
NO MERCY!
Default Re: (C Squared)
So what kind of internals do you have to upgrade in order for the engine to handle more than the 250 wtq that I believe it's rated to handle max???
Old Jan 1, 2007 | 09:43 PM
20strong's Avatar
Im waiting for the jackson racing supercharger. Internals? What should be changed to run s/c?
Old Jan 1, 2007 | 10:26 PM
hyogen's Avatar
so how does the S/C and T/C affect gas mileage.
from what I gather so far I think I'd probably like having a supercharger more... I'd like more torque.
gas mileage effects for both? Thanks
Old Jan 1, 2007 | 10:45 PM
Default Re: (hyogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyogen &raquo;</TD></TR><TR><TD CLASS="quote">so how does the S/C and T/C affect gas mileage.
gas mileage effects for both? Thanks </TD></TR></TABLE>
yes...a 3-4 drop on gas mileage at cruise speed...and flooring it u might expect a decrease of 5-6 mpg. There's a guy with a big turbo here making 370whp and 250w torque getting 22+/- mpg flooring it.
Old Jan 2, 2007 | 06:17 AM
Nohawk's Avatar
As far as added weight to the car, do you all think the s/c is much greater than the AJP turbo? I heard that the s/c could have alot better gains if it were not as heavy. Not sure on this though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">S/C = Power that is on all the time, but lower gains.
T/C = Has to spool, but once it does... </TD></TR></TABLE>
Also, the s/c using the engine to power it and power will peak. Turbos use exhaust to spool creating the gains.
Old Jan 2, 2007 | 07:05 AM
RICO_'s Avatar
NO MERCY!
Default Re: (Si 4 Life)
AJP Turbo &gt; S/C
Old Jan 2, 2007 | 07:07 AM
Nohawk's Avatar
Default Re: (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">AJP Turbo &gt; S/C</TD></TR></TABLE>
Agreed. I don't even consider getting the s/c.
Old Jan 2, 2007 | 07:24 AM
RICO_'s Avatar
NO MERCY!
Default Re: (TypeRBoy)
Define "you guys". I'm pretty sure not EVERYBODY made that conclusion.
Old Jan 2, 2007 | 07:41 AM
The Answer's Avatar
/\ Hah, always so serious.
Old Jan 2, 2007 | 08:20 AM
RICO_'s Avatar
NO MERCY!
Default Re: (RICO_)
Yet at the same time i believe you're very limited with a turbo setup on the FG2 cause the compression is real high. So you can't really up the PSI too much.
They both have their strong and weak points.! Either choice is a good one.
Old Jan 2, 2007 | 09:26 AM
Nohawk's Avatar
Jackson Racing also has a s/c out. http://www.showstoppersusa.com...=1295
I wonder which is better. Comptech vs. JR
