timing belt snaped... :(
Old Dec 28, 2006 | 09:58 PM
GsrTurboCRX88's Avatar
Default timing belt snaped... :(
My timing belt snaped on my way home from work today. I herd that it doesnt always bend the valves. is that true? I had a prelude with an h23 and when the timing belt snaped i needed a head job. what do you guys think
Old Dec 28, 2006 | 10:20 PM
oodie's Avatar
Default Re: timing belt snaped... :( (GsrTurboCRX88)
You didnt try to restart it did you? you might have got lucky and not bent any
Old Dec 28, 2006 | 10:28 PM
TeamRedline89Hatch's Avatar
My buddy snapped his timing belt on his dohc zc and it didn't hurt a thing. The thing is...he was on a residential street...at 25 mph.
Old Dec 28, 2006 | 10:50 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: timing belt snaped... :( (TeamRedline89Hatch)
its pretty rare that you dont bend any valves at all. i would say to put a new belt on and check compression. if any cylinders are bad, either try to find a head at the junkyard, or go with a sohc vtec d15. rebuilding is way too costly when higher horsepower replacement engines can be had for half the price of a rebuild. assuming you are stock of course..
Old Dec 28, 2006 | 10:58 PM
i did crank it over once but imediately stopped cause i could tell the belt was broke
Old Dec 29, 2006 | 12:36 AM
Spoon Sports's Avatar
Suit up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">My timing belt snaped on my way home from work today. I herd that it doesnt always bend the valves. is that true? I had a prelude with an h23 and when the timing belt snaped i needed a head job. what do you guys think</TD></TR></TABLE>
same thing happened to me.
It was on my old D15 engine. My friend replaced it and it worked fine.
Old Dec 29, 2006 | 01:44 AM
charlee's Avatar
Default Re: timing belt snaped... :( (Spoon Sports)
i dont think D series are interfericnece engines. meaning they wont hit the pistons. altho i could be wrong
Old Dec 29, 2006 | 05:24 AM
Loserkidwac's Avatar
Default Re: timing belt snaped... :( (charlee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlee &raquo;</TD></TR><TR><TD CLASS="quote">i dont think D series are interfericnece engines. meaning they wont hit the pistons. altho i could be wrong</TD></TR></TABLE>
You are wrong
yea throw a new belt on it and see what happens, d series heads are cheap
Old Dec 29, 2006 | 05:53 AM
s10cky's Avatar
I have a y8 head and a a6 head if you need one, hell even a d15b2 head.
Old Dec 29, 2006 | 06:08 AM
s10cky's Avatar
The valves are most likely bent if this is the case.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">i did crank it over once but imediately stopped cause i could tell the belt was broke</TD></TR></TABLE>
Old Dec 29, 2006 | 06:11 AM
shortyz21's Avatar
Default Re: timing belt snaped... :( (s10cky)
check the pistons to. the valves can dent them pretty good..
Old Dec 29, 2006 | 06:15 AM
Hondasmo's Avatar
Only thing you can do is put a new belt on and cross your fingers ...
Old Dec 29, 2006 | 06:20 AM
Hondasmo's Avatar
Default Re: timing belt snaped... :( (Hondasmo)
Ive put timing belts on hondas at work after people have broken them and the engines worked just fine but these people werent street racing or snatching gears at the time the belt broke either more of just cruising along with the flow of traffic
Old Dec 29, 2006 | 10:02 AM
colnago's Avatar
replace belt and see how it runs. bent valves will cause engine to run rough at idle. engine will still run though.
colnago
Old Dec 29, 2006 | 10:25 AM
EL Vap133's Avatar
Default Re: timing belt snaped... :( (colnago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colnago &raquo;</TD></TR><TR><TD CLASS="quote">replace belt and see how it runs. bent valves will cause engine to run rough at idle. engine will still run though.
colnago</TD></TR></TABLE>
True, and then you will know if you need a new engine or not.
Old Dec 29, 2006 | 10:43 AM
crxmissing's Avatar
Default Re: timing belt snaped... :( (EL Vap133)
yeah dude i would have that all check out
Old Dec 29, 2006 | 12:20 PM
Default Re: timing belt snaped... :( (crxmissing)
i will look at it this weekend. i was prolly going like 30 or 35. the thing is the belt looks new, the teeth dont have any wear on them so i am wondering if the cam siezed up or something
Old Dec 29, 2006 | 12:41 PM
tilt's Avatar
Ive fixed a d15b2 that snapped its belt on the freeway. No bent valves.
Old Dec 29, 2006 | 06:31 PM
charlee's Avatar
Default Re: timing belt snaped... :( (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">
You are wrong
=O! *goes and cries*
Old Dec 29, 2006 | 06:58 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">i will look at it this weekend. i was prolly going like 30 or 35. the thing is the belt looks new, the teeth dont have any wear on them so i am wondering if the cam siezed up or something</TD></TR></TABLE>
make sure the distributor bearing isnt seized, will snap a belt in a heartbeat.
Old Dec 30, 2006 | 06:08 AM
crxmissing's Avatar
Default Re: timing belt snaped... :( (schardbody)
I'm With this idea something i think is wrong inside. check if u see orange dust or red / orange wire under the cap something must of took a ****. we all know honda distributer can just go whenever with no sign...
Old Dec 31, 2006 | 11:57 AM
sanimalp's Avatar
$cat /dev/urandom
i can vouch for the seized distributor bearing as well. it happened to me and acted just like a timing belt issue.
you can pull the distributor off with 3 bolts. then try to rotate the engine and check with the top timing cover off. have somene watch the belt and make sure there are no missing teeth. if the cam doesnt rotate with the crank rotation, then your timing belt is toast. if it rotates just fine, get a new distributor and do your timing and youll be ok. good luck.
Cripton805
Jan 9, 2022 07:15 PM
Gvis420
13
Dec 20, 2009 12:24 PM
thunderboy
Aug 21, 2008 05:05 PM
rpv173
Jul 23, 2005 10:19 PM
E-Rok
Jun 19, 2003 10:04 AM
