daytime running lights (DRL)
Old Dec 28, 2006 | 07:15 PM
kidsafe 750's Avatar
Default daytime running lights (DRL)
I have a 93 cx that was made in canada and it has daytime running lights. Unfortunally i dont have my fuse box cover. So does any one know what fuse my DRL is? or a pic that shows me? cause i want to disable them. I dont like them.
Thanks
Old Dec 28, 2006 | 07:40 PM
qat727's Avatar
Default Re: daytime running lights (huntcopsnotdeer)
There are several fuses in the DRL system. Compared to the USDM non-DRL system, under-hood fuse No. 39 (50A) is added. That goes to a white/black wire that connects to a white wire going to the ignition switch. A wire also comes off of the circuit connected to under-hood fuse No. 40 (40A), but this fuse is the main one for the headlights. Under-dash fuses No. 17 (10A) and No. 16 (7.5A) both go to the DRL Control Unit under the dash.
From the looks of the circuit, I'd try pulling fuse 39 first, and if everything still works except the DRL, great. If something doesn't work, I'd leave 39, and pull 17 and 16.
Hope this helps, let me know how it works.
(I'm not responsible if you screw up and blow your car up. Be careful)
S33
Dec 27, 2014 10:22 AM
ay_billy
10
Sep 10, 2011 09:24 PM
blackakkord
Jan 31, 2008 05:46 PM
Cee_mon
Jul 20, 2005 07:27 PM
1990crx
14
Apr 12, 2005 12:28 PM
