LS in EF swap, question about boomslang directions/TPS wiring
Old Dec 28, 2006 | 07:03 PM
JokerTypeR's Avatar
Default LS in EF swap, question about boomslang directions/TPS wiring
I'm damn near done with my LS in EF project, but I'm looking at the wiring for the TPS.
Note:
B18A1 motor
91 honda civic car
Boomslang OBD0-OBD1 DPFI conversion harness
PR4 ECU (92-93 Integra)
--Let me know if you need more information...
Alright, back on topic. The directions for the boomslang harness direct me to take the three wires to the TPS and switch the outer two (yellow/white and green)
I was wondering, though, if I should follow these directions. The conversion harness is to wire in for a VTEC setup. Should the TPS wires be switched ONLY if I'm wiring in a VTEC engine? Or since I'm not going VTEC, should I leave them the way they are originally?
Please advise. Thanks in advance.
Old Dec 28, 2006 | 08:17 PM
s10cky's Avatar
dont know about this one. good luck. (this is why I went with a plug and play from rywire, lol.)
mahatma's Avatar
Default Re: LS in EF swap, question about boomslang directions/TPS wiring (JokerTypeR)
i have the EXACT same setup as you
and i switched the outer 2 wires around, runs perfect
Old Dec 28, 2006 | 08:22 PM
JokerTypeR's Avatar
Default Re: LS in EF swap, question about boomslang directions/TPS wiring (mahatma)
That's what I'm lookin' for. Hey, mahatma, if you wanna throw me pictures of those vac lines in my other thread, it'd be a huge help.
Also, you mind if I contact you for future questions on the wiring?
For example...my dizzy, I'm trying to wire it in...did you have two white wires coming from your previously used wiring harness?
And as for the harness from Rywire...I thought about it. 350 or 360$ didn't seem worth it...
Old Dec 28, 2006 | 08:41 PM
civickiller's Avatar
you must switch the tps wires or your ecu will think its wot instead of being closed.
as far as dist. your 2 white wires are already there, you just need to add wires for crank angle, its 2 wires that should be blu/yel and blu/grn. if you got a obd1 dist, it might be a grn/yel wire on yoru dist side and that goes to the fatter of your 2 white wires. its the white wire that isnt in the shield
Old Dec 28, 2006 | 08:46 PM
s10cky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
And as for the harness from Rywire...I thought about it. 350 or 360$ didn't seem worth it...</TD></TR></TABLE>
your obviously not ballin like me. J/K!
Old Dec 28, 2006 | 08:49 PM
mahatma's Avatar
i went to snap a few pics for ya, but my gf put the digicam batteries in the charger backwards
the white wires had me stumped for a while too....i had some trouble deciding which one was 'fat' & which was 'skinny', so i ran battery power to them, then tested to see which was which down at the ecu plugs. this thread may help with that
https://honda-tech.com/zero...age=2
i can get vacuum pics soon if you still need them. i removed the charcoal canister during my swap too, that helps cut down on vacuum lines all together, and hence less confusion
Old Dec 29, 2006 | 06:30 AM
JokerTypeR's Avatar
Default Re: LS in EF swap, question about boomslang directions/TPS wiring (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">you must switch the tps wires or your ecu will think its wot instead of being closed.</TD></TR></TABLE>
LoL...I was wondering what they did...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">it might be a grn/yel wire on yoru dist side and that goes to the fatter of your 2 white wires. its the white wire that isnt in the shield</TD></TR></TABLE>
That's a HUGE help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">your obviously not ballin like me. J/K! </TD></TR></TABLE>
1. 20 years old
2. No job
3. Full time student
4. NGCSU Corps of Cadets (Military student)
...nope...not ballin'...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">i went to snap a few pics for ya, but my gf put the digicam batteries in the charger backwards
i can get vacuum pics soon if you still need them. i removed the charcoal canister during my swap too, that helps cut down on vacuum lines all together, and hence less confusion</TD></TR></TABLE>
I'd definitly be interested to see this done. Just so long as I can pass the sniffer test, and get the full power from the engine, that's all I give a damn about...
Old Dec 29, 2006 | 07:49 AM
JokerTypeR's Avatar
Mahatma, what'd you do with your TCS (tandem control valve) or whatever that thing is that hooks to the back of the old DPFI system. Has a black/yel wire and an orange wire on a white connector...
Old Dec 30, 2006 | 01:03 AM
Default Re: (JokerTypeR)
you dont use the tandem control value or the wires. just leave them hanging or just cut them off and use them for teh swap
Old Dec 30, 2006 | 04:11 AM
JokerTypeR's Avatar
Default Re: (civickiller)
Alright, what should I do with the vtec wires? The light blue, green, red, and pink? I think you said you used the Boomslang harness, right? Just wondering what to do with these wires...
I'm getting frustrated with this engine swap...I'm gonna get a compression tester today to make sure all four are getting full compression.
Old Dec 31, 2006 | 05:14 AM
i just ran all the wires through the firewall and i put all the wires in a wire loom. i taped all the wires i didnt use together then taped that to the o2 wires so if i ever decide on going vtec later on, the wires are already thourgh just sitting there waiting
Old Dec 31, 2006 | 10:05 AM
green91's Avatar
dahlonega b-series swaps FTW
Old Dec 31, 2006 | 02:36 PM
JokerTypeR's Avatar
Default Re: (green91)
Well, I'm actually located in woodstock for the swap, but I live at the school. You know there's a run tomorrow at 10am at the home depot in dawsonville? Well, that's where they're meeting. I was gonna run, but I'm an exhaust manifold gasket and 3 half-shaft bolts shy...
Old Dec 31, 2006 | 02:46 PM
green91's Avatar
yea my honda isnt in run condition and unless its 100 % dry my 240sx is like ice skates.. so im gonna sit it out. plus im selling my 240 so dont need to risk wrecking it lol.
Justinleexxx
21
Aug 19, 2014 12:40 PM
EF9_RIDER37
Oct 15, 2009 09:12 PM
1badeghb
Dec 12, 2006 10:18 PM
drowzysleeper
Aug 25, 2005 02:49 PM
