everything needed for a gsr swap in an ls
Old May 13, 2002 | 12:50 PM
1hotintegra's Avatar
Default everything needed for a gsr swap in an ls
i have a 94 ls integra 5sp. i have 130k miles now. my engine now burns a little bit of oil, which isnt too bad considering the miles. well i want to swap the engine with a gs-r with LOW miles. I wanted to know what is needed. I want to know everything down to the last nut and bolt. (ecu upgrade, oil pump, ETC.) Also where can i get a Gs-r engine for a pretty good price. *Keep in mind i am on kind of a low budget. Any other coments are welcome
Old May 13, 2002 | 06:18 PM
Default Re: everything needed for a gsr swap in an ls (1hotintegra)
ttt
Old May 13, 2002 | 09:25 PM
shamoo's Avatar
Will you make something up for me please?
Motor
Tranny
Axles (including intermediary shaft)
Linkages
ECU
Wiring Harness
EDIT: Your LS is a 5-speed already, so some things can be saved, like your center console, motor mounts, etc.
[Modified by shamoo, 1:26 AM 5/14/2002]
Old May 14, 2002 | 08:09 AM
Default Re: everything needed for a gsr swap in an ls (shamoo)
how much $$$ do u think this will run
Old May 14, 2002 | 08:22 AM
shamoo's Avatar
Everything legit with papers, should be around $3000 to $3500. This is, of course, a GSR motor in reasonable condition with not too many miles.
No labor either.
Old May 15, 2002 | 05:58 AM
phatintegra's Avatar
Where can you get one for a good price??
Old May 15, 2002 | 08:04 AM
shamoo's Avatar
Default Re: everything needed for a gsr swap in an ls (phatintegra)
Try to find them used.....if you're lucky from a salvage yard even. Try Ebay, http://www.thepartstrader.com , people here on HT, classified forums on other message boards, etc.
fastmhz
Jan 9, 2011 11:28 PM
jikespingleton
Dec 2, 2006 04:18 PM
IntegraDriver
Feb 9, 2005 08:11 AM
1hotintegra
May 15, 2002 05:58 AM
1hotintegra
May 15, 2002 05:57 AM
