Need some tips on a swap
Old Dec 28, 2006 | 03:35 PM
rtnlsltn's Avatar
Default Need some tips on a swap
I blew my LS block on my lsvtec, so i picked up a GSR block, and ill be putting the GSR head on the block i just got. Just looking for some info on preparation of both of them before i put them together as far as cleaning and/or lubrication. I cleaned the block out as good as i can, theres still some antifreeze around the rings that i cant get to. The head is still on the LS block, i'm waiting to see if theres any tips you guys may have before i remove it. This is my first swap, so any info would be helpfull. Also, ill be swapping my LSD out of my trans into another one i picked up, any tips on that?
Old Dec 28, 2006 | 04:20 PM
rtnlsltn's Avatar
Default Re: Need some tips on a swap (rtnlsltn)
up, google isnt returning answers for me on the LSD.
Old Dec 28, 2006 | 06:19 PM
Fezzie's Avatar
any lsd is good as long as you have one, but i would say take your block and head to a shop, get the block and head hot tanked, an have the shop do a valve job and the anti-freeze in the block dunt worry about that its fine, wont hurt anything.
lsd's: OBX-aorund $375, Quaife-around $8-9 hundred(dunt kno if i spelled that right), ctr, itr <--- both around same price 375
Old Dec 28, 2006 | 09:34 PM
rtnlsltn's Avatar
Default Re: Need some tips on a swap (fezzie)
i already have an LSD, i just have to take it out of my current trans and put it in my newer one. I got the casing almost off, i just need a ring installatio tool to get the last part loose, i think i can handle that much. Hot tanking is a good idea, but im not sure if i want to do valves, that gets pricey from what i recall...
Old Dec 29, 2006 | 08:15 AM
Fezzie's Avatar
no just a valve job is cheap i had a three angle done for like 50 bucks i think it was but im using oem gsr valves so i didnt spend too much on my valvetrain
Old Dec 29, 2006 | 02:01 PM
rtnlsltn's Avatar
oh damn, not bad. hmm..
ef_si
Aug 10, 2013 12:55 PM
skateboard_ej8
Apr 10, 2008 10:06 AM
knuckk
Jan 9, 2008 08:49 AM
brownkobe
Jun 14, 2007 08:34 PM
Lewcis
Jul 29, 2004 09:19 PM
