Problem with car starting
Old Dec 28, 2006 | 12:21 PM
b16a2coupe's Avatar
Default Problem with car starting
i have a 97 ek sedan and im having problems with starting it after i finished installing my new motor and turbo kit. i did the swap with a few of my friends and was very careful about wiring and all. i finished yesterday and wnet to start it and all its doing is the starter click. my fuel pump isnt even turning on nor my headlights. but my corners my cluster and my dome light all turn on. so in essence im not getting spark nor fuel. any suggestions about what is wrong? thanks in advance.
Old Dec 28, 2006 | 12:28 PM
EJ-081's Avatar
you probably blew the main fuse in the engine bay dude that happened to me a while back when i was doin my conversion....
Old Dec 28, 2006 | 12:35 PM
b16a2coupe's Avatar
Default Re: (EJ-081)
the battery one or one of the others under the hood?
Old Dec 28, 2006 | 03:01 PM
b16a2coupe's Avatar
Default Re: (b16a2coupe)
TTT
Old Dec 28, 2006 | 03:04 PM
Lightweight Boost's Avatar
check the battery connections . have someone try to start it while you wiggle the battery leads . this should fi the problem . MAKE SURE its in park or neutral . I had the same prob and my wife dumped the clutch when it started and hit my knee . I hadnt cried that hard since i was 13
Old Dec 28, 2006 | 03:32 PM
b16a2coupe's Avatar
Default Re: (Lightweight Boost)
that was tried
its not the battery. because im not getting fuel or spark ... i think it might be a fuse but i havent been able to look at it 2nite.
sl0waccord
Mar 3, 2012 03:13 PM
phikshin
Jun 28, 2009 07:04 PM
tooljst8
Mar 23, 2008 12:39 PM
tico
Aug 22, 2006 02:32 PM
g2tegsown
Aug 4, 2005 05:19 PM
