****HELP!!! SIR REAR & FRONT DISC CONVERSION QUESTION...*****
Old Dec 27, 2006 | 11:04 PM
EF_PINOYGUY's Avatar
Default ****HELP!!! SIR REAR & FRONT DISC CONVERSION QUESTION...*****
Hi all!..Was wondering if any of you peepz had any suggestions or know what to get for replacement rotors and brake pads for the front & rear knuckles of a SIR Ef9 from japan..I need New rotor's & brake pad's bad for my SIR disc set up on my 90 civic hatch, but I don't know what fits..I was thinking 92-93 integra GSR, but not sure...I just installed these on my 90 hatch, but need to replace everything..If you guys need rotor measurements, I can post it tomorrow if that helps...Thank you in advance..
B..
Old Dec 28, 2006 | 08:48 AM
EL Vap133's Avatar
Default Re: ****HELP!!! SIR REAR & FRONT DISC CONVERSION QUESTION...***** (EF_PINOYGUY)
I think the closest match is the DA brake hardware.
Old Dec 28, 2006 | 10:01 AM
Boosted Chemist's Avatar
Default Re: ****HELP!!! SIR REAR & FRONT DISC CONVERSION QUESTION...***** (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I think the closest match is the DA brake hardware. </TD></TR></TABLE>
x2, i think all teg stuff is the same, minus the r of coarse (90+)
Old Dec 28, 2006 | 10:34 AM
pendejon's Avatar
from what i recall, the front suspension on an SIR is all the same stuff from a DA integra. you should try measuring the rotors, and comparing the pads to any DA pads. i have 90-93 integra rotors and calipers on my car, (well i think the calipers are DA, i gotta check that out), and the rotors are half inch more diameter than normal crx si front rotors.
Old Dec 28, 2006 | 08:30 PM
Default Re: (pendejon)
Thanx for all the suggestions guyz...I will measure them up in a fewa and will let everybody know...Yeah, I think Im gonna try some DA stuff first...
Old Dec 28, 2006 | 08:33 PM
EL Vap133's Avatar
Default Re: (EF_PINOYGUY)
Rotors are pretty much universal in the 10.2" size. Just take the pads with you to a local auto parts.
nj400ex
Dec 4, 2013 09:18 AM
Devil CRX
Oct 8, 2009 09:33 AM
91bluehatch
Suspension & Brakes
Mar 19, 2009 04:56 PM
EF_PINOYGUY
Jan 2, 2007 12:05 AM
Blazin Civic
Suspension & Brakes
Jun 10, 2005 11:43 PM
