Anyone ever tried adjusting cam gears on a stock GSR??
Old Dec 27, 2006 | 10:17 PM
J-Spot's Avatar
Default Anyone ever tried adjusting cam gears on a stock GSR??
I have a Eg hatch with a GSR in it. I have a skunk2 pro mani, JDM ITR header, JG adjustable cam gears, clutch & a flywheel. My question to you guys out there is that my friend is nagging me on adjusting my cam gears to get everything I can out of the stock cam (valvetrain)?? Would it make a difference. I figured I would just leave it stock but unless otherwise someone on here played with their cam gears?? Any info would be appreciated.. OH BTW I am running a chipped ECU..Vtec engages at 5600 if that helps. thanks.
Old Dec 27, 2006 | 11:07 PM
ABK's Avatar
ABK
Default Re: Anyone ever tried adjusting cam gears on a stock GSR?? (J-Spot)
it's pointless. And your vtec is set way too high.
Old Dec 28, 2006 | 06:11 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: Anyone ever tried adjusting cam gears on a stock GSR?? (ABK)
Yep.
Old Dec 28, 2006 | 09:44 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Anyone ever tried adjusting cam gears on a stock GSR?? (black_EM1)
Leave cam gears alone until you get on a dyno. You CAN pull out some more power from cam gear adjustments, you just need to be on a dyno for it.
Old Dec 28, 2006 | 11:24 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
ya adjusting cam gears is only good to do it on the dyno just set ur vtec lower and dyno it and get bigger cams and ull feel a way bigger diff in performance
Old Dec 28, 2006 | 02:20 PM
doood's Avatar
been there done that
Default Re: (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">ya adjusting cam gears is only good to do it on the dyno just set ur vtec lower and dyno it and get bigger cams and ull feel a way bigger diff in performance</TD></TR></TABLE>
wtf??
Boostedtracksol
Apr 20, 2006 08:56 AM
f22abuilder
Feb 16, 2006 06:10 AM
Phatch99
Jul 28, 2004 12:04 PM
insnimprtguy
Jul 17, 2002 02:11 PM
