93 ALL MOTOR integra... COLORADO
1993 integra ls special edition
jdm one pieces, jdm gsr fenders, password jdm c/f hood, black interior, clarion audio, diamond audio speakers all around (m3 series)
1995 gsr block
new water pump
new oil pump
(gsr type r)
moroso 5 quart baffled oil pan (with bungs in pan)
1995 gsr crank (micro-polished)
King Motorsports main and rod bearings
ARP head and main studs
JUN stage 3 camshafts
B16 head port and polished
Comp cams valvesprings and steel retainers
pct (civic type r) pistons
GSR rods with arp rod bolt upgrade
8.8lb act xact flywheel
stage 3 6 puck dual spring clutch
greddy high tension timing belt
type r intake manifold with bored throttle body
rc 310cc injectors
upper and lower tie bars front and rear
tein s tech springs on tokico hp’s
front and rear camber kit (vaos with recent 4 wheel alignment)
jdm y-1 trans w/ QUIFE lsd and ls 5th gear
energy suspension motor mount inserts (all 4) , shifter upgrade kit, and rear trailing arm inserts
dc adjustable cam gears
megan header, option mid pipe, ractive dtm muffler and high flow catalytic converter
over 8k invested.. letting go for 5.5 or best offer...
6500 miles on build 194k on CLEAN OHIO TITLE...
best run in ohio 13.5@108 car has only seen 11 1/4 mile passes...
retiring from the game, getting back into dirtbikes..
Modified by b18cda6 at 9:27 PM 12/27/2006
Modified by b18cda6 at 10:27 PM 12/27/2006
1995 gsr block
new water pump
new oil pump
(gsr type r)
rc 310cc injectors
simplsi
Mid-Atlantic (Sales)
12
Aug 24, 2008 11:09 PM
