Need ECU pin help.. OBDII wiring service connector? Out of date 98 integra Haynes manual?!
Hey I already posted this in the integra forum with no reply. I figured its electronic fab
Original post-
Hey I have a chopped up what i think is 98 Integra gsr harness and the service connector has been cut out same with srs electronics and abs control module. I have a 98 Haynes manual that has all the wiring diagrams which help out on where things should be but it looks like they screwed up on wire colors or am I missing something here?? In the pics is the ecm wires on 94-97 and on 98 models but it looks like nothing mates up color wise to my ecu connectors...
I am trying to find the service connector wires so when i run my car i can check the cel codes. In the pic the arrow is pointing to what i think is the service connector wire. I cant find the black wire cause there are a few that have been cut. I read in another post that i can install a switch instead of jumping the connector. So all i have to do is connect the brown/white wire in the pic and then ground the second wire to the switch is this right? Thanks for the help.
Original post-
If you <u>think</u> it's a 98 gsr harness and none of the wire colors match, then it's probably NOT a 98 gsr harness
jweller well it has the correct colors for the vtec solenoid and the vtec oil pressure sender and a few others here and there, but alot of them are off
Can anyone please confirm that this brown /white wire as being the check diagnostics code wire?!? It will only take like 10 mins looking under ur dash please
DL the whole Helms for free:
http://www.hondahookup.com/manuals/
I dont ever trust Haynes nor Chilton
thanks thermal ur the man. Signed up logged in, and now i kinda wish i didnt ask. That manual is so in depth its crazy compared to the "figure it out" haynes manuals. Theres like 2000 pages and im on 1500 on like the 500 devoted to electrical
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8 GS-R »</TD></TR><TR><TD CLASS="quote">thanks thermal ur the man. Signed up logged in, and now i kinda wish i didnt ask. That manual is so in depth its crazy compared to the "figure it out" haynes manuals. Theres like 2000 pages and im on 1500 on like the 500 devoted to electrical </TD></TR></TABLE>
No problem mang...
No problem mang...
cudaboy
May 31, 2016 03:04 PM
XLR8 GS-R
Dec 27, 2006 02:31 PM
