a6 crank pulley & z6 crank pulley the same?
i was wondering if an aftermarket a6 crank pulley is the same if i get z6 crank pulley. the z6 is to bug i dont need the pw streeing, and ac part on the pully, i only need the alternator part. the only crank pully that sells it wit only the alt... part is the a6 pulley.
Avoid aftermarket crank pulleys unless God himself has demanded that you install one. If you choose to install one anyways, your bearings may just up and leave you.
civictypenos
Aug 23, 2003 12:53 AM
