d relays to try to wire up these mirrirs and all the wiring diagramswiring up ctr mirrors?
Old Dec 27, 2006 | 06:17 PM
siblues's Avatar
Default How to wire up ctr mirrors?
I ordered two different switches and all the wiring diagrams that I have found have the wires set up differently on the back of the plugs?The relay plug is correct but the wires on the switch are set up differently the open spot is in a different location.I also wanted to know if i just use a 12volt source and ground if I could just check wire by wire to see what each one will do without harming the mirrors,switch or relay?The ground wire is open and the open pin on the left is occupies on my switch and the second pin from the right on the top row is open too?Thanks Antonio
SpoonEk253
40
Aug 17, 2009 10:56 PM
RenzoDaPlayboi
Feb 4, 2008 12:00 PM
frankie11
30
Jun 29, 2007 09:58 AM
spikerockz
Dec 3, 2005 06:35 PM
type r 01-1063
Dec 13, 2003 06:08 PM
