Supertech V-train w/Skunk2 Pro2 cams "Will it work??
will my Supertech V-train SPR-H100DR work with the Skunk2 Pro2 cams?
Is there any mods that i need to do the Rocker arms?
will GSr LMa's be ok?
Need to kno all this stuff before i drop these cams in..... Thanks in advance...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">gsr LMA ok?
so im guessing just drop these ******* in like it's all good??
yes. gsr lmas are ok. what year are they?
look like one of these?
</TD></TR></TABLE>yes. gsr lmas are ok. what year are they?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote"> i kno, cause i have try the pro1's and it idles like ****....
i kno this is the same thing too, due to the big lobes on the primaries
No, your tuner just sucks.
Find a competent tuner, and your idle will be just peachy.
My LSVTEC on Pro2+'s idles very well.
- Derek
</TD></TR></TABLE>No, your tuner just sucks.
- Derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">
Yeap, I've seen a good tuner and Pro2 in a stock GSR, idle like stock.
Running Supertech valvetrain+valves with Pro2's. No clearance problems with ITR LMA.
The quality of your idle is directly proportinal to the quality of your tuner. Mine idles and goes thru warmup just like stock, no hunting or high idle...
i kno this is the same thing too, due to the big lobes on the primaries </TD></TR></TABLE>
yea your tuner sux ***
the tuner may not really suck ***. What some people call a stock idle may be rough in other peoples minds. A friend of mine has a well prepared ls/vtec with pro1's tuned by jeff evans. It idles steady, but i'd consider it a tad rough and annoying. Jeff himself said that they vary and that the pro2 generally seem to idle smoother. Not putting down the pro series at all, they are most definitely kick *** cams
i agree with runnerdown, people have different ideas on what constitutes a steady idle. my pro1's idled without dying, but it was a bit unsteady and lopey, it was really annoying in daily driving
I'm a rookie on tuning, but I love my pro 2's on my B18C-R with only a Toda valve train. Took me a while to figure out the idle, but thanks to everyone who helped me out.
b19coupe
92TypeR
b19coupe
92TypeR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">i agree with runnerdown, people have different ideas on what constitutes a steady idle. my pro1's idled without dying, but it was a bit unsteady and lopey, it was really annoying in daily driving</TD></TR></TABLE>
its a fact. pro1's are annoying. and, i also heard p2's idle better than p1's. regardless of what anyone says, i own a set of p1's. they don't idle like stock. the term "like stock" is broad and misunderstood term.
Supertech Springs
Cosworth Springs
RLZ Springs
Enduratec Springs
Schmithelm Springs
Which part numbers are you guys using. There's about 3 different "official" Supertech part numbers for BVTEC and you can use other p/n's if you got a spring set-up that is drastically different than stock.
Cosworth Springs
RLZ Springs
Enduratec Springs
Schmithelm Springs
Would you guys run the Ferrea springs that are recommended for up to 13mm of net lift with the PRO2's?
As a note i have used PRO2' with other aftermarket springs and they coil binded after roughly 1000 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2Racing »</TD></TR><TR><TD CLASS="quote">Skunk2 cams suck look at k20A.org they lost their *** to IPS</TD></TR></TABLE>
Ummm... Funny, I didn't know this thread had anything to do with K-series engines...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2Racing »</TD></TR><TR><TD CLASS="quote">AND THEIR RETAINERS ONLY LAST 15,000 MILES</TD></TR></TABLE>
Again, that's funny, my Skunk2 retainers that I've had for YEARS are still looking JUST fine.
Now leave this place. Be gone, evil, horribly misinformed noob!
- Derek
- Derek
wrongm, they won peak hp
my skunk2 retainers saw over 20k miles of abuse with no signs of wear.
My rocket motorsports valvetrain saw over 50k miles of 9900rpms an NEVER showed signs of fatigue
shut the expletive up with the bullshit talk
