jdm zc pistons in d16y8
Old Dec 27, 2006 | 05:08 PM
CALC!_JUST_du_IT!'s Avatar
Default jdm zc pistons in d16y8
ok... so yesterday someone told me i could get around 11.5:1cr in my y8 with jdm zc pistons. i was given this link: http://www.zealautowerks.com/dseries.html. i put in all my specs, and the zc pistons would yield about 12.69:1cr! i would have to use a head gasket about twice the thickness (0.070in) as my stock gasket (0.037in) to get close to 11.5:1cr. is that safe? will it put too much tension on my timing belt? also, i need someone to tell me whether or not these pistons will hit the valves. is there anything wrong with this setup? i plan on using my stock y8 crank and zc rods. (if it matters, i'm going with 0.020in overbore pistons as my cylinder walls may be scored)
Old Dec 27, 2006 | 05:14 PM
Default Re: jdm zc pistons in d16y8 (CALC!_JUST_du_IT!)
c'mon... i really need some advice here. i've been trying to get some answers for the past few days.
Old Dec 27, 2006 | 05:34 PM
ninor's Avatar
zc pistons are too much comp for y8. Not a street proposition. End of story
Old Dec 27, 2006 | 06:36 PM
Default Re: (ninor)
how do you suggest i get that kind of compression? i can't find aftermarket pistons above 10.5:1cr. should i go with those and mil the head?
Old Dec 28, 2006 | 07:26 AM
cafcwest's Avatar
Default Re: (CALC!_JUST_du_IT!)
Well backtop D16A1 (88-89 Integra) should be ROUGHLY .4 lower compression, all factors the same, than a blacktop ZC piston. A browntop D16A1 (86-87 Integra) should be 1.0 point of compression lower than a blacktop ZC piston, again all factors being the same. But I know there are a lot of other choices out there, for new cast piston money you'd probably be close to some cheaper forged pistons out there.
Old Dec 28, 2006 | 07:47 AM
Boots's Avatar
Default Re: (cafcwest)
i say try it...if you blow something up, its a d series and you can replace it for super cheap
Old Dec 28, 2006 | 06:34 PM
ZC16Y8's Avatar
New User
Default Re: (boots)
u used the d16a1 (88-89) integra pistons they r exactly the same as a zc pretty much. i used those on my y8 and the motor popped because the compression was so high id do it again but im recommending u run a thick head gasket and it will be fine . and just so u know it was worth it that car hauled ***
Old Dec 28, 2006 | 06:37 PM
Dibble's Avatar
SRP makes some 11.1 pistons. You will pay more, but they are well worth the price IMO.
You can get a 3 layer head gasket and get 12.1 out of A1 pistons in a y8. Maybe a mild port job and nice crower stage 2 cam. That would be a nice little fun daily driver NA dseries.
puertoricanboy90
Dec 2, 2008 11:02 PM
CALC!_JUST_du_IT!
Dec 27, 2006 05:33 PM
CALC!_JUST_du_IT!
Dec 27, 2006 12:01 PM
1point7db2
Oct 4, 2005 02:52 PM
Spade
27
Jun 1, 2003 08:26 AM
