zc pistons in y8
Old Dec 27, 2006 | 04:55 PM
CALC!_JUST_du_IT!'s Avatar
Default zc pistons in y8
ok... so yesterday someone told me i could get around 11.5:1cr in my y8 with jdm zc pistons. i was given this link: http://www.zealautowerks.com/dseries.html. i put in all my specs, and the zc pistons would yield about 12.69:1cr! i would have to use a head gasket about twice the thickness (0.070in) as my stock gasket (0.037in) to get close to 11.5:1cr. is that safe? will it put too much tension on my timing belt? also, i need someone to tell me whether or not these pistons will hit the valves. is there anything wrong with this setup? i plan on using my stock y8 crank and zc rods. (if it matters, i'm going with 0.020in overbore pistons as my cylinder walls may be scored)
Old Dec 27, 2006 | 05:10 PM
Default Re: zc pistons in y8 (CALC!_JUST_du_IT!)
don't leave me hangin... can anybody help me? should i go to the all motor forum?
Old Dec 27, 2006 | 05:33 PM
claytonsmith's Avatar
it should be in all motor.. as far as clearing ... the valves SHOULD clear.. they have reliefs cut in the pistons
twice as thick? im not aware of a head gasket that is that much thicker than stock.. cometic may make a D series on that is that thick.. and a6 headgasket is almost 2x the stock thickness... but i dont belive that will work.. no hole for the oil port stuff etc
CALC!_JUST_du_IT!
Dec 28, 2006 06:37 PM
CALC!_JUST_du_IT!
Dec 27, 2006 12:01 PM
1point7db2
Oct 4, 2005 02:52 PM
Spade
27
Jun 1, 2003 08:26 AM
Don Napier
19
Nov 17, 2002 08:32 PM
