IACV or TPS
Old Dec 27, 2006 | 02:29 PM
wannakno's Avatar
Default IACV or TPS
I have searched and wanted to get a more acurrate answer/opinion from you all.
I have a 93 accord LX with an IDLE fluctuation ONLY in park or Neutral. When I start the car it it jumps to 2500 RPM and fluctuates from there. I unplugged the TPS and the idle stays at about 2000 RPM or so.
Before you ask, I checked:
-for vacuum leaks and have found none.
-checked the egr and seems to be operating fine.
-I also tried cleaning the TB with TB cleaner, to make sure it wasn't sticking.
Your help is appreciated
Old Dec 27, 2006 | 05:40 PM
hondadude's Avatar
Default Re: IACV or TPS (wannakno)
it's a vacum leak, turn the adjuster inside the FITV in a couple turns
Mike Heath
Feb 21, 2018 02:44 AM
zfollette
Jan 30, 2016 02:12 PM
ezgo123
Aug 29, 2012 10:38 PM
james007
Apr 30, 2010 04:26 PM
LeftCorner
Aug 6, 2002 08:20 PM
