90 ACCORD wont start HELP!!
Old Dec 27, 2006 | 12:23 PM
YodajdmEK4's Avatar
Default 90 ACCORD wont start HELP!!
I have a 1990 Accord EX that was runnin fine and then it just wouldnt start. I thought it was the battery because it looked in bad shape so I replaced it and it cranks but still doesnt start. Any ideas? Anything would help??
Old Dec 27, 2006 | 12:39 PM
jimjonez
Guest
Posts: n/a
Default Re: 90 ACCORD wont start HELP!! (YodajdmEK4)
did you check your distributor rotor and cap? how about spark plugs and cables? that is what it sounds like to me
Old Dec 27, 2006 | 12:47 PM
YodajdmEK4's Avatar
Default Re: 90 ACCORD wont start HELP!! (jimjonez)
thats next on my list, it sounds to me likes there not enough spark to make it start but the car belongs to my gf grandma so haven taken a full look at it but just trying to get ahead of the problem
Old Dec 27, 2006 | 02:05 PM
hondadude's Avatar
When you DO ACTUALLY get to the car, turn on the key and listen for the fuel pump to run for a few seconds. How many miles on this creampuff?
When was the T-belt replaced? Has it stripped some teeth?
Check for spark to the plugs, if not, Use a test light to see if the ignition switch is putting power to the Black/yellow wire at the dist. while cranking.
If you have power to the dist. the most likely problem is the ignitor, with the coil running a close second.
dsettlemoir
May 7, 2016 03:34 AM
Boostedyota
Jun 14, 2009 05:18 PM
nickmcpher
Aug 21, 2008 05:10 PM
digital_cowboy
Jul 7, 2007 06:37 PM
pstutz
Jan 16, 2002 07:25 AM
