aluminized steel
All you need to do is strip the coating off ~1" from the weld. Otherwise the burning gas is a bit toxic. Once its stripped, its just mild steel. Any cheap MIG will work on it. A mild steel flange will be best, as you usually only get surface rust on a 1/2" slab of steel. The vast majority of stainless manifolds come with mild steel flanges.
BeArDy
Welding / Fabrication
12
May 18, 2011 01:50 AM
AzntaggeR
Mar 21, 2005 08:55 PM
