Speedo wont work
Old Dec 27, 2006 | 08:15 AM
platinumx6's Avatar
Default Speedo wont work
Alright everything on my cluster works minus the speedo and the odometer. Its either the speed sensor or the wiring harness ive leanred thru searching but i cant find the part number or the difficulty to change the speed sensor. Im guessing its just the actual sensor since the gas/temp etc works.
So how much is it, how hard is it to do, and where the hell is it located. Thats what i cant find through searching.
Thanks for info
Old Dec 27, 2006 | 08:34 AM
Beckington's Avatar
Default Re: Speedo wont work (platinumx6)
its located on the top of the tranny, almost directly underneath the TB.
its one 10mm bolt, thats kind of shaped wierd...and its located towards the right back.
Unbolt it, pull it out of its home...and unclip the harness at the top (grey).
Reverse for re-installation. Its super easy.
Old Dec 27, 2006 | 08:36 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Speedo wont work (Beckington)
and to add to that...
what tranny is it? i was able to use a vehicle speed sensor from a d-series tranny on my b18c1 tranny.
Old Dec 27, 2006 | 08:38 AM
platinumx6's Avatar
d series DX tranny
Old Dec 27, 2006 | 12:58 PM
mikhsoj's ep3-05si's Avatar
Default Re: (platinumx6)
i have a speed sensor that works. let me know. ill toss it ur way for 25
Old Dec 27, 2006 | 02:32 PM
D15Bbigred's Avatar
is it not working at all? or does it sometimes work? cause thats my current problem and i've narrowed it down to a crack in the sauter on the back of my cluster. the connectivity is a little jumpy. i always thought if it was your vss your going to pull a cel. but good luck
Old Dec 29, 2006 | 07:49 AM
platinumx6's Avatar
yeah i get a cel SOMETIMES, and the speedo never works. Yes before the cel came on i searched and found it was the speed sencor then i check the cel and sure enough.
Thanks every1
Black90CrxSi
Feb 14, 2009 03:14 PM
chulopilong
Dec 31, 2004 12:26 PM
jaydm ferio
Dec 6, 2004 06:57 PM
veilsides2000
Nov 5, 2004 10:52 AM
vtekthis
Mar 25, 2004 10:39 PM
