TEIN SS QUESTION/HELP
Like the topic says, I have the tein SS installed on a 97 accord. When going over a quick drop in the road not bump or pot hole usually the front left makes a loud klunk sound. I already checked all the bolts bottom & top everything seems tight.
Does anyone have any ideas?
My Integra only makes a loud "klunk" when I run out of suspension travel and slam the UCA into the fender.
Are you certain that you have adequate suspension travel? Do you have the correct bumpstops in place? Used a zip tie to check how much of the shock travel is being used during normal driving conditions?
the tein SS came completely assembled. Ride height wise it has a 2 finger gap, which is now why I'm lead to believe it could be my control arm bushings.
