90-91 crx parts on a 88 crx?
Old Dec 26, 2006 | 08:33 PM
drvfast's Avatar
Default 90-91 crx parts on a 88 crx?
Will 90-91 crx parts fit on a 88crx? Parts such as: the moldings, front bumper, rear tail lights, drivers side window, head lights and so on..........
Old Dec 26, 2006 | 08:48 PM
1 Fly SI's Avatar
Default Re: 90-91 crx parts on a 88 crx? (drvfast)
The moldings will but they are smaller. The front bumper will, the tail lights,and the headlights will also, But the headlights housing is different so you will have to get 2 small things from a 90-91 off the fender.(corner lights don't bolt on the same.) The windows i'm not sure about since you don't have door mounted seat belts.
Old Dec 27, 2006 | 09:41 AM
89efDUSTY's Avatar
Default Re: 90-91 crx parts on a 88 crx? (1 Fly SI)
http://www.quickhonda.net/yearDiffs.htm ...that is the most i can find...this is also posted more then once...SEARCH
Old Dec 27, 2006 | 09:50 AM
Loserkidwac's Avatar
Default Re: 90-91 crx parts on a 88 crx? (89efDUSTY)
Window won't work.. the 88 had the pillar mounted seat belts and the 90-91(also 89 DX and Si) had the door mounted seatbelt which lead to have a window that is about 1-2" shorter from front to back...
Old Dec 28, 2006 | 01:26 AM
drvfast's Avatar
Default Re: 90-91 crx parts on a 88 crx? (Loserkidwac)
thanks guys, thats what I needed to hear.
Old Dec 29, 2006 | 04:13 PM
LatnKng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">Will 90-91 crx parts fit on a 88crx? Parts such as: the moldings, front bumper, rear tail lights, drivers side window, head lights and so on..........</TD></TR></TABLE>
Most stuff will fit, but some wont because the 90-91 had bigger parts added on those years, and the 88-89 had mostly small parts, or shorter i should say. Good luck though, i'd try.
Old Dec 29, 2006 | 04:53 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 90-91 crx parts on a 88 crx? (LatnKng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LatnKng &raquo;</TD></TR><TR><TD CLASS="quote">
Most stuff will fit, but some wont because the 90-91 had bigger parts added on those years, and the 88-89 had mostly small parts, or shorter i should say. Good luck though, i'd try. </TD></TR></TABLE>
What? You are wrong dude! Parts are the same bloody size. My 89 Si has 91 bumpers, doors, headlights, corners and tails, no diff in size
Sipocketrocket
Sep 10, 2009 08:02 PM
inh
Jul 13, 2006 05:26 AM
B-serious
Jun 1, 2006 05:17 AM
Torino91LS
Jul 21, 2003 11:37 AM
RapeV-8
Jan 10, 2003 07:02 PM
