will a gsr block girdle fit a b18a for a ls/vtec?
Old Dec 26, 2006 | 01:36 PM
EG93si's Avatar
Default will a gsr block girdle fit a b18a for a ls/vtec?
as the question states?
Old Dec 26, 2006 | 02:02 PM
my_slow_civic's Avatar
Default Re: will a gsr block girdle fit a b18a for a ls/vtec? (EG93si)
Not without some machine work.
Old Dec 26, 2006 | 02:16 PM
nateg's Avatar
are you serious?, can you explain a little better, i was under the assumption that it would?
Old Dec 26, 2006 | 04:58 PM
SPITVENOM67's Avatar
Default Re: (nateg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nateg &raquo;</TD></TR><TR><TD CLASS="quote">are you serious?, can you explain a little better, i was under the assumption that it would?</TD></TR></TABLE>
no they wont very different blocks the if what you are trying to say is can u put the oil squirters and vtec girdle ? then No because they wont bolt up..
Old Dec 29, 2006 | 06:51 AM
EG93si's Avatar
Default Re: (SPITVENOM67)
i was just talking about subing in the gsr girdle (thing that acts as the middle three main caps on the crank) in place of the actual middle three main caps on a b18a block, idc about the oil skirters, just seemed like a little insurance, ive got one off my buddies gsr, then i have mine off my b16, would you suggest one in my lsvtec?
wwcrxww
11
Jan 6, 2010 03:32 PM
fatpride111
Apr 10, 2008 06:08 AM
Simple
Aug 22, 2005 08:04 AM
LSVTEC 91 Civic
Apr 2, 2005 12:50 PM
1quickhatch
46
Feb 1, 2005 11:40 PM
