motor not starting after swap...clutch sensor?
Old Dec 26, 2006 | 12:44 PM
G60's Avatar
G60
Default motor not starting after swap...clutch sensor?
I just swapped the D15 in my civic for another one, same motor. Kept the old tranny. Finally got it all finished up today, went to start it and nothing happened, but there was a ton of slack in the clutch. Went to the clutch adjustment and tightened everything up, but the motor still won't try to start. Battery has 12V, its not even trying, something is keeping it from putting power to the starter. Where is the sensor for the clutch, perhaps that is bad? Any other ideas for stuff to double check?
Old Dec 26, 2006 | 12:55 PM
dr_latino999's Avatar
Default Re: motor not starting after swap...clutch sensor? (G60)
Clutch switch is right above your clutch pedal. Make sure it has a clean contact with the pedal, or you can just jump the switch with a wire.
Old Dec 26, 2006 | 01:45 PM
Suck my DX's Avatar
check all your fuses and grounds...is the starter hooked up properly...check the wire that goes from the starter to the underhood fuse box...ive seen people forget to hook that up
Old Feb 2, 2008 | 08:14 AM
zc89hatch's Avatar
Default Re: motor not starting after swap...clutch sensor? (dr_latino999)
is there a way i can use that clutch switch and hide it some where like a button for a kill switch
Old Feb 2, 2008 | 09:49 AM
sgallagher's Avatar
Default Re: motor not starting after swap...clutch sensor? (zc89hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zc89hatch &raquo;</TD></TR><TR><TD CLASS="quote">is there a way i can use that clutch switch and hide it some where like a button for a kill switch</TD></TR></TABLE>
Sure why not, you might want to wire it to another switch so it not obvious.
As for your starting problem...Check your grounds to the engine/trans. if not hooked up or if they do not have good contact the starter will not crank.
KimvdLinde
Jun 29, 2013 12:19 PM
ThaSpitefulWun
Mar 1, 2005 09:35 AM
atli126
14
Feb 16, 2005 04:17 PM
yaleforizzle
Dec 8, 2003 06:34 AM
p0pe
Sep 20, 2003 07:52 PM
