13:1 compression
Old Dec 26, 2006 | 06:46 AM
CXtypeR's Avatar
Default 13:1 compression
will it be possible to run 13:1 compression on 93 octane as a daily driver? with tuning of course
Old Dec 26, 2006 | 06:54 AM
BrOkEn_Dc2's Avatar
Default Re: 13:1 compression (CXtypeR)
My friend is for the moment... lots of smoke... hes fixing it. lol. you should get an upgraded head at least! What are your mods?
Old Dec 26, 2006 | 08:15 AM
d16dcoe45's Avatar
Default Re: 13:1 compression (type B16)
Are those Formula Atlantic motors? They don't use any production parts--the heads are different castings, the cranks are not factory, practically none of the parts in the motor are oem Toyota. I don't believe that there are 250 hp 4age builds running around with oem heads, blocks and cranks.
Running 13:1 on pump gas is stupid. Why do it? So you can say you have a 13:1 motor, but you have to run 18 degrees total timing? Why not 11.5--make more power and have a more reliable motor? Unless you plan on running 100+. I have a 12:1 motor that I broke in using nothing but 100 octane Sunoco 260 unleaded--now I use a 50/50 mix of 100/93 which gives me around 96-97--I am able to run 29 degrees total timing and more if I use the straight 100 (I was running up to 32 for a little while) but where I am, the Sunoco 260 is $7.99/gallon!!
Old Dec 26, 2006 | 09:00 AM
xDicktonesx's Avatar
Default Re: 13:1 compression (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">Are those Formula Atlantic motors? They don't use any production parts--the heads are different castings, the cranks are not factory, practically none of the parts in the motor are oem Toyota. I don't believe that there are 250 hp 4age builds running around with oem heads, blocks and cranks.
Running 13:1 on pump gas is stupid. Why do it? So you can say you have a 13:1 motor, but you have to run 18 degrees total timing? Why not 11.5--make more power and have a more reliable motor? Unless you plan on running 100+. I have a 12:1 motor that I broke in using nothing but 100 octane Sunoco 260 unleaded--now I use a 50/50 mix of 100/93 which gives me around 96-97--I am able to run 29 degrees total timing and more if I use the straight 100 (I was running up to 32 for a little while) but where I am, the Sunoco 260 is $7.99/gallon!!</TD></TR></TABLE>
this is honda-tech. that kind of advice falls upon deaf ears. because in about 3 posts, someone will come in here and talk about "his homies lsvtec with ctr pistons that is 13.5:1 that runs on pump gas and it beat this one kids camaro so it must be fine"
Old Dec 26, 2006 | 09:15 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 13:1 compression (xDEFTONESx)
On Honda Tech tuning makes the motor run perfect and ends world hunger.
Old Dec 26, 2006 | 09:49 AM
91SiZ6's Avatar
Hahaha. You should see the flame war on D-Series.org about exactly that.
Old Dec 26, 2006 | 11:34 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">this is honda-tech. that kind of advice falls upon deaf ears. because in about 3 posts, someone will come in here and talk about "his homies lsvtec with ctr pistons that is 13.5:1 that runs on pump gas and it beat this one kids camaro so it must be fine"</TD></TR></TABLE>
dude my buddy has a B20/Vtec revving 10K with 14:1 compression that runs 87 grade and beat my other buddies SLR.
Old Dec 26, 2006 | 11:42 AM
Default Re: 13:1 compression (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">
dude my buddy has a B20/Vtec revving 10K with 14:1 compression that runs 87 grade and beat my other buddies SLR. </TD></TR></TABLE>
&lt;chuckle&gt; the rev thing is another one that just tickles my taint.
Old Dec 26, 2006 | 11:46 AM
itralex's Avatar
Its possible, but i wouldn't reccommend it
I run 13.1:1 on the streets with 94octane and it totally blows *****. My timing sucks and you can't beat on it on the street. When I put in VP104 it runs better but i only get that at the local track.
I should've double checked my calculations first before getting my pistons, I wanted something in the range of 12.0-12.5:1
Old Dec 26, 2006 | 01:55 PM
d16dcoe45's Avatar
Default Re: 13:1 compression (itralex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">Its possible, but i wouldn't reccommend it
I should've double checked my calculations first before getting my pistons, I wanted something in the range of 12.0-12.5:1</TD></TR></TABLE>
Now here is an honest post that I can appreciate--I appreciate your honesty and frankness about the reality of crazy compression. I think everyone here would love to run 14:1 if they could get away with it on pump gas, but over a certain point you just wind up with a less reliable motor that makes less power than a similar build running more reasonable compression with more timing. Super compression is hell on bearings and what works and doesn't rattle in a 1/4 mile of full throttle may not work to well going up a steep hill in 3rd gear in 100 degree heat.
flat out 99
Jan 17, 2012 02:32 AM
SoFresh1189
Jan 26, 2010 02:32 PM
d16dcoe45
Nov 27, 2006 10:15 AM
cornholioEK
May 21, 2003 07:22 AM
Charlie Moua
Sep 27, 2002 04:03 AM
