ECU programing service. will put a base map for what u have in ur car.
ECU programing service. I will put a base map for what u have in your car. this is for the chipping sevice only. I dyno alot of different types of cars and can usually get a good base map for you to make HP with out the dyno I just need to know everything you have in ur car. you just need to send my any obd1 ecu. i will socket it and remove whatever that is needed and put in 2 main chips and the needed capacitors to make the program work. The service cost $85.00 bucks and you can send your ecu to 15081 moran st. ste.D westminster ca 92683 and call me at 714-878-5008 name is david for a limited time only
Modified by gofastcrx at 2:17 AM 12/26/2006
gofastcrx
May 8, 2007 10:35 PM
Del Sol on Steroids
Nov 25, 2006 04:22 AM
Del Sol on Steroids
Nov 25, 2006 12:33 AM
