ECU programing service. will put a base map for what u have in ur car.
Old Dec 25, 2006 | 09:56 PM
gofastcrx's Avatar
Default ECU programing service. will put a base map for what u have in ur car.
ECU programing service. I will put a base map for what u have in your car. this is for the chipping sevice only. I dyno alot of different types of cars and can usually get a good base map for you to make HP with out the dyno I just need to know everything you have in ur car. you just need to send my any obd1 ecu. i will socket it and remove whatever that is needed and put in 2 main chips and the needed capacitors to make the program work. The service cost $85.00 bucks and you can send your ecu to 15081 moran st. ste.D westminster ca 92683 and call me at 714-878-5008 name is david for a limited time only
Modified by gofastcrx at 2:17 AM 12/26/2006
Old Dec 26, 2006 | 01:18 AM
gofastcrx's Avatar
Old Dec 28, 2006 | 08:15 AM
gofastcrx's Avatar
1223241113333312312321312
Old Jan 28, 2007 | 11:35 AM
gofastcrx's Avatar
Default Re: (gofastcrx)
adfasf
Old Feb 5, 2007 | 06:05 AM
gofastcrx's Avatar
Old Feb 24, 2007 | 11:21 PM
gofastcrx's Avatar
honda
Old May 8, 2007 | 10:35 PM
sleeplsm's Avatar
* B A N N E D *
Default Re: ECU programing service. will put a base map for what u have in ur car. (gofastcrx)
bump
j0keefe21
Jul 7, 2009 11:33 AM
kobeballer96
Mar 16, 2009 07:35 PM
adam00
Engine Management and Tuning
Jan 26, 2009 09:19 PM
gofastcrx
Dec 28, 2006 08:13 AM
Del Sol on Steroids
Nov 25, 2006 04:22 AM
