'86 CRX Si - Hatchback "Chittering/Squeaking" Noise
Old Dec 25, 2006 | 07:24 PM
celt101's Avatar
Default '86 CRX Si - Hatchback "Chittering/Squeaking" Noise
Mother has owned captioned car since new. Shortly after leaving the lot, the latch on the hatchback started making this chittering/squeaking noise. Dealership unable to fix other than applying lithium grease, which is a temporary (about 5 minutes) fix at best. As car has aged, noise is more persistent.
Does anyone know if there is a permanent fix for this...some kind of aftermarket part that can go in there or if Honda ever put out any kind of tech bulletin on this that we could take to the current dealer and say "here, fix per these instructions"? Or, even better, something simple we could do ourselves (not mechanically inclined BTW).
Thanks
Old Dec 26, 2006 | 04:04 AM
Sikocivic's Avatar
Default Re: '86 CRX Si - Hatchback "Chittering/Squeaking" Noise (celt101)
This is a common problem with many "fixes" that people have used. Do a search for a squeaking hatch and see what you find.
Old Dec 26, 2006 | 07:00 AM
Tetanus's Avatar
Default Re: '86 CRX Si - Hatchback "Chittering/Squeaking" Noise (Sikocivic)
I wrapped the part of the mechanism on the hatch with electrical tape on my CRX. Give it a try
Old Dec 26, 2006 | 08:15 AM
Suck my DX's Avatar
Default Re: '86 CRX Si - Hatchback "Chittering/Squeaking" Noise (Braddy)
try twisting the adjusters all the way out...also if you can pinpoint where the squeaking is coming from give the hatch a nice tug in the opposite direction...this may help...other than that find something that you can stick between the two rubbing parts thats not gonna wear down wicked fast....
Corksil
Jan 1, 2012 10:51 AM
Guitar333
Honda Civic (2001 - 2005)
May 21, 2010 08:25 PM
johnzm
Jun 1, 2003 07:49 PM
Rincon
Jun 18, 2002 01:05 PM
io_burn
Oct 28, 2001 05:36 AM
