what is the flow of the radiator
Old Dec 25, 2006 | 04:31 PM
rewerbcrx's Avatar
Default what is the flow of the radiator
what directions does the radiator flow in ... i have never looked and or had any interest too but i am curious now...
??????from top head to radiator->lower radiator to back of block???????
thanks
Old Dec 25, 2006 | 04:48 PM
Pooby88's Avatar
Default Re: what is the flow of the radiator (rewerbcrx)
The water goes from the radiator through the top hose into the engine. When the engine warms up, the thermostat opens and releases the water into the lower hose, and back to the radiator.
Old Dec 25, 2006 | 04:50 PM
Crx Jimmy's Avatar
Default Re: what is the flow of the radiator (Pooby88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooby88 &raquo;</TD></TR><TR><TD CLASS="quote">The water goes from the radiator through the top hose into the engine. When the engine warms up, the thermostat opens and releases the water into the lower hose, and back to the radiator.</TD></TR></TABLE>
you have it backwards
you can fill the rad up half way and when it heats up you can see it coming out the top hose
Old Dec 25, 2006 | 07:33 PM
rewerbcrx's Avatar
Default Re: what is the flow of the radiator (Crx Jimmy)
so the flow is come from radiator into bottom hose through block into head and back to radiator... did i get it right lol
Old Dec 25, 2006 | 07:47 PM
92civicfreak's Avatar
yea i'm sure its that ways... cuz i remember thinking that first way & then bering wrong...
Old Dec 25, 2006 | 08:26 PM
Pooby88's Avatar
Default Re: (92civicfreak)
Maybe I was wrong. I just know that the top hose gets hot first, then when the thermostat opens, the lower hose gets hot.
Old Dec 25, 2006 | 08:42 PM
there are probly many reasons the top hose gets warm first, one its shorter & closer to the block, & 2 that would be the inlet hose... where all the fluid is running from the engine into the radiator... remember the radiator is supposed to COOL the fluid....
but on the subjects... my car runs way too cold sometimes
Shehzada
Sep 21, 2014 01:47 PM
thunderfck
Mar 9, 2013 09:48 AM
fanta!
Aug 14, 2005 02:14 PM
B18Redline
Dec 2, 2004 09:35 AM
Sam268
Nov 3, 2003 09:12 AM
