Nausiatingly specific description
I'm sure that this problem is or if it will require a special solution but since I'm not sure of it I will attempt describing it.
It's a 1999 Honda Accord 4 door Automatic 4cyl.
It has a little over 100,000 miles and the best part is ..... it's paid off !!!
The bad part is when I shift from reverse to forward I need to wait patiently with my foot on the brake for the shifting to take effect. That doesn't bother me especially since I've read that the wait is debatably normal. I don't believe it since that would make my car the only one I know of to fix itself but I digress.
The problem I DO have is when I'm accelerating from 0 as it's shifting into the next gear it winds high and kicks in hard. I have enough fluid in it for sure. More than I should I'd wager seeing as the level is about an inch above full. That ain't the problem. Bathing the gears in a cascade if fresh fluid actually fixed it for about a half hour but then it was back to feeling like I was being love tapped by a tardy commuter every time I got started moving.
The other (possibly related) problem/symptom is that when I come to a complete stop I need to wait for my car to understand my intentions to do so. When I do stop I feel what is almost like the exact opposite of when I start. I feel like someone is bumping me. It feels like my transmission can't get back out of the one low gear it has trouble getting into until 1-2 seconds after my car has stopped.
If it's just the matter of a flush I'd be happy to hear it but if I have change the *glorp* I don't even want to say it.
Sorry if that was a bit long winded.
you'll probably end up needing a rebuilt tranny unfortunately.
the kicking hard might be a solenoid. similar symptoms happened to me before in my 98 saturn sl2, and the stealership charged $400.
This may be a patronizing question, but... Do you have Honda ATF in there? You really do need to use the Honda branded stuff, and I should know. A second-rate shop filled my tranny with generic fluid, and it surged on the 3-2 shift and stuff. With the Honda ATF it's been shifting much smoother.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">I've never heard of them doing it for a 4-cyl auto before... but it doesn't hurt to try.</TD></TR></TABLE>
I have a friend they did it for. must depend on the dealer
Man... I wish I knew what your friend said to get them to do it. None of the dealerships here in Houston would even think about doing it for me. Even the dealership I used to work at couldn't do it for me, and they take care of a lot of stuff for me. Or maybe I just need to move to Maryland...
