Woot!!! TWN short shifter, metal bushing and shift knob installed
my girlfriend got it for me for christmas and the car feels a million times better now. I love it so much and it's the best upgrade ever!!!!!
Install guide: http://www.newcelica.org/other...x.htm
Update:
Modified by kroze at 12:23 PM 12/25/2006
Modified by kroze at 12:26 PM 12/25/2006
Update:
you now need a weighted shift ****. let me tell you, it feels incredible to put the car into gear.
Its weighted so it gives a leverage feel there for smoother shifts due to the effortless entry into the next gear due to the added weight i am getting my skunk2 weighted shift **** very soon i cant wait !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 »</TD></TR><TR><TD CLASS="quote">should at least post pics of the install/process and such...
can someone please explain to me the purpose of a "weighted" shift ****? I honestly don't understand it..</TD></TR></TABLE>
From TWM's faq
5. What is the advantage of having a TWM shift **** on my short shifter?
Because the **** weighs over 500 grams it acts as a counterweight for the shift lever. This added weight at the top of the shifter reduces the amount of effort needed to shift.
personally i'm going with circuithero.. they are over a lb!
From TWM's faq
it's pretty simple and straight forward. I'll take a pic or two later on to show you the finish product.
Here's the install guide for the short shifter/bushing and console removal.
A weighted shift **** makes shifting so much easier & precise. It require very little effort to shift and it goes into gear without any troubles at all. The bushing makes it even better because you don't feel that rubbery bounce when you shift or push left / right on the shifter.
it's pretty simple and straight forward. I'll take a pic or two later on to show you the finish product.Here's the install guide for the short shifter/bushing and console removal.
the install is so easy.
i installed my comptech SS, and it took 30 minutes only because the screw fell into my center console...
weighted shift ***** make it easier to shift
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-Dawg »</TD></TR><TR><TD CLASS="quote">What does adding the bushing do vs. say...the comptech ss? Is it worth it?</TD></TR></TABLE>
whhhat?? please rephrase the question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kroze »</TD></TR><TR><TD CLASS="quote">
whhhat?? please rephrase the question.</TD></TR></TABLE>
i think he means does the bushings add to the setup since both the comptech & twm are similar short shifters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X »</TD></TR><TR><TD CLASS="quote">
i think he means does the bushings add to the setup since both the comptech & twm are similar short shifters.</TD></TR></TABLE>
Right, seems like the difference is that one comes with this "bushing." Basically, what does this do?
the metal bushing replace the stock rubber ones. the different is huge.
normally when you push left & right on the shifter, you can feel the springy/rubbery bounce with the stock bushing. Once the metal bushing installed, no more spring/bounce back. it feels a lot more clear & precise when you shift.
it's kinda of hard to explain but everything just feels so much more clean/crisp/precise now. no more freeplay on the shifter.
add that with the short shifter, and the weighted shift ****, & since the shift **** is countersink, the shifter is shorter than stock.
the car is so much more enjoyable to drive & shift.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-Dawg »</TD></TR><TR><TD CLASS="quote">The difference probably won't be as dramatic on the si, but I'm still interested. How much is a good price for the ss/bushing?</TD></TR></TABLE>
any reason why you would write that comment? or just speculation?
I've read NUMEROUS reviews on " the ocho " on how its the best mod people have done on the civic..... Si
I've read NUMEROUS reviews on " the ocho " on how its the best mod people have done on the civic..... Si</TD></TR></TABLE>
I just mean that the OP did his install on a DX. Since the si already has a much better feel in shifts than the DX, I'm sure the difference is even *greater* for him
<<<< Hmmm... I don't about all that, ever since I've been on this site all I've heard about were problems with the shifting in the Si when it came to 2nd and 3rd gear... never heard anything bad about the 5 spd tranny..... and just because it's not an Si doesn't mean the quality of the product is absolute crap.
No not at all! Who knew I was about to get flamed for this =P
I just mean that the close-ratio feel and I guess the gearbox itself, in general, feel better in the si (vs. the EX I've driven also, in particular). Either way, I guess the idea here is that this is a great upgrade for either model
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-Dawg »</TD></TR><TR><TD CLASS="quote">I just mean that the close-ratio feel and I guess the gearbox itself, in general, feel better in the si (vs. the EX I've driven also, in particular). Either way, I guess the idea here is that this is a great upgrade for either model
I would agree.
</TD></TR></TABLE>I would agree.
hold on now...the bushings did not make that big of a difference. I drove around with the short shifter for a while before adding the bushings and it made the biggest difference. The bushings just made a slight difference...have you actually seen these rubber mounts...its not as squishy as everyone is making it out to be...and on top of that there are metal inserts going into the rubber! If you already have the comptech ss your not going to dramatically see some amazing thing in the feel of the shift with the bushings. I should post pics of these rubber bushings with the metal insert...and how it is held in the shifter. On top of that the bolts that are holding in these rubber bushings are put in soo tight (factory torque) that the rubber wouldnt have a chance to go anywhere. I was thinking that the rubber was possibly for reducing vibration within the shifter...IMO.
