will a crx si wire harness work with a b16?
Old Dec 25, 2006 | 08:32 AM
importgod21682's Avatar
Default will a crx si wire harness work with a b16?
i was wondering if a stock wire harness would work with a b16 i do know that the b16 is obd1 and the si harness is obdo but was wondering if it would work even with modification.
Old Dec 25, 2006 | 08:35 AM
crxpwr1's Avatar
Default Re: will a crx si wire harness work with a b16? (importgod21682)
you have to convert your wiring harness...to save you time and frustration I would send it to rywire
Old Dec 25, 2006 | 08:47 AM
Default Re: will a crx si wire harness work with a b16? (crxpwr1)
is a there a wireing harness i could use?
Old Dec 25, 2006 | 09:33 AM
HondaPartsHero's Avatar
Technical Hero
It depends if you want to convert your SI to OBD1. If you do you will need:
-OBD1 ECU
-OBD0-1 ECU adaptor
-OBD0-1 distributor adaptor
-Add wiring for VTEC solenoid, VTEC pressure switch, knock sensor
-either use your OBD0 injectors with the resistor box or use the OBD1 injectors without the resistor box
If you stay OBD0 you will have to swap over your injectors onto the B16A and run the wiring for VTEC solenoid, VTEC Pressure switch, Knock sensor, and 2nd O2. And run a PR3/PWO OBD0 ECU.
ef dino
Jun 1, 2007 07:04 AM
mitsuman
Mar 30, 2007 10:52 PM
89 JDM CRX
Jun 20, 2004 09:38 PM
SI_Ro
Dec 13, 2003 01:49 PM
Lysawy
Oct 22, 2003 06:03 AM
