Sport Comp2 tach jumps
Old Dec 25, 2006 | 08:28 AM
drSquish's Avatar
Default Sport Comp2 tach jumps
I recently built my B16 for an all-motor setup. It was converted to OBD-1. After the build I installed the aforementioned tachometer only to find the needle will jump to random points when the engine is between 3 and 4 thousand RPMs. Anything above or below that reads accurate. Autometer told me it was my magneto ingnition. Help?
Old Dec 25, 2006 | 09:37 AM
EFvtec Yo!'s Avatar
Might want to check out the wires on your ignitor in your dizzy. If those terminals are loose on there your tach will jump around a good bit. Does the car have a stock tach too, and if so does it jump?
Old Dec 25, 2006 | 11:28 AM
d16dcoe45's Avatar
Default Re: (EFvtec Yo!)
I can almost guarentee you have a loose coil wire or an intermittent connection--I had the same thing happen many years ago and that is always the problem.
Old Dec 25, 2006 | 01:12 PM
drSquish's Avatar
stock tach works fine. The coil is a MSD Blaster 2. The wire is seated properly. Any other suggestions?
Old Dec 25, 2006 | 06:23 PM
frostyrb's Avatar
Default Re: (drSquish)
The distr. is getting ready to take a ****. Get a new distr.
Old Dec 28, 2006 | 11:36 AM
drSquish's Avatar
Let me reiterate myself; the stock tach works fine.
Old Dec 28, 2006 | 01:20 PM
d16dcoe45's Avatar
There is a bad connection somewhere connecting your Autometer tach to the coil--your stock tach is not as sensitive as the Autometer so it may not show an intermittent connection like the Autometer would. I would use a DVOM and check resistance in your connection wires from the Autometer to the coil.
crito07
May 12, 2007 08:44 AM
dbiker207
Mar 31, 2007 04:41 PM
hughesl
May 15, 2005 03:39 AM
Beezle
Nov 2, 2004 10:33 AM
infamousALLMTR
Aug 2, 2001 04:46 AM
