Brake Light Problem: Need help ASAP
Old Dec 24, 2006 | 07:51 PM
b18civic1993's Avatar
Default Brake Light Problem: Need help ASAP
hows it goin eveyone. i recently bought a 92 civic cx shell and had to swap everything from my dx into it. it had a single cam vtec in it and what i believe is a cx dash with a passenger air bag. he cut the SRS air bag main power cable right before the box so i had to swap all my stuff into it along with everything else becides the dash harness. Now all my fuses are good and everything but the brake and horn work and the SRS light is on. what could possibly do this. does the SRS need to be reset or am i missing something stupid ? ive checked all the fuses, even replaced them with brand new ones. replaced the brake switch with a new one and put new bulbs in it just to be sure. any advice would be greatly apreciated cause its driving me nuts not being able to drive my car. thanks
Old Dec 24, 2006 | 08:08 PM
9200RPM's Avatar
Default Re: Brake Light Problem: Need help ASAP (b18civic1993)
for the srs light
https://honda-tech.com/zerothread?id=264288
as far as the brake light have you checked the grounds...
Old Dec 25, 2006 | 06:01 AM
all grounds are good. dosent the srs system affect the brake lights from working? I understood it was all the same circuit?
Old Dec 26, 2006 | 06:08 PM
9200RPM's Avatar
Default Re: (b18civic1993)
that im not sure of...was that link any help as far as reseting anything...and if all else fails rewire that ish
kornkid21792
Jun 4, 2009 01:16 PM
tousaephanh
Sep 10, 2008 04:22 AM
outlawstar27
May 18, 2007 09:04 AM
JforJonathan
Mar 23, 2004 05:29 PM
