B.C. III cams, which valves springs?
Old Dec 24, 2006 | 06:22 PM
all-mtr-teg's Avatar
Default B.C. III cams, which valves springs?
Which valves springs would you use for b.c. 3 cams? I was thinking of upgrading my itr springs, and i had supertech and omni valves springs in mind. what yould you use and why?
Old Dec 24, 2006 | 08:09 PM
Default Re: B.C. III cams, which valves springs? (all-mtr-teg)
ttt.
Old Dec 24, 2006 | 09:25 PM
gsrious's Avatar
bc springs... why not.
you use bc cams, then use bc springs.
Old Dec 24, 2006 | 09:32 PM
Combustion Contraption's Avatar
Please dont bump your own threads "to the top" in a timespan of under 2 hours. If your question is worth answering, someone will answer it.
Old Dec 24, 2006 | 10:14 PM
Default Re: (gsrious)
because the omni and supertech are a bit less expensive than the b.c. valves springs, but i was wondering if they are sufficient for the b.c. 3 cams.
Old Dec 24, 2006 | 10:15 PM
Default Re: (Combustion Contraption)
thanks for the advice, i'm just a little anxious to get the v.s. ordered to get it tuned hopefully next week.
Old Dec 24, 2006 | 11:45 PM
GetawayInMoscow's Avatar
Default Re: (all-mtr-teg)
just get whatever...omni, rocket, b.c., skunk2, etc...
Old Dec 25, 2006 | 09:36 AM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">bc springs... why not.
you use bc cams, then use bc springs.</TD></TR></TABLE>
Don't waste your money on BC springs.
Rocket, Supertech, or OMNI.
Old Dec 25, 2006 | 11:01 AM
Jerms's Avatar
You don't need springs for bc3 cams
Old Dec 25, 2006 | 02:44 PM
smileycvc's Avatar
Default Re: (Jerms)
I have the BCIV and use the omni springs. So I assume that they would hold up to the III's.
Old Dec 25, 2006 | 08:43 PM
Default Re: (smileycvc)
Yeah, im leaning towards omni since i heard they supposedly wear out the cam lobes less than much stiffer springs like RM.
Teamdiesel
Jun 5, 2009 04:03 PM
b18c5 EG
Dec 2, 2005 10:07 AM
baxter04
Jul 27, 2005 07:34 PM
Dan Hill
Aug 19, 2002 10:23 PM
