Will a 93 stock oem full si catback exhaust be a direct boltin on my 95 civic hatch cx.
well.. also depends on what motor you ahve in the CX
cx has the cat in the header where SI has a cat between the header and exhaust.. so technically it wont bolt direct to a stock cx unless you use the si cat or test pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">well.. also depends on what motor you have in the CX
cx has the cat in the header where SI has a cat between the header and exhaust.. so technically it wont bolt direct to a stock cx unless you use the si cat or test pipe</TD></TR></TABLE>
yes it will bolt on directly.
you will have to cats.
denraweb
Jul 24, 2009 09:48 PM
HELLAnorcal
10
Nov 21, 2006 06:22 AM
TOTAL-TUNING
25
Mar 19, 2005 07:45 PM
