car wont go into gear!!! NEED HELP!!!
Ok first off I have a 96 civic ex and it has an act stage 1 clutch it has been in for over a year with no problems. I was driving home on Thursday and put the clutch in to go to neutral to come to a stop that was fine put the clutch in to go and nothing it would not go into any gear no signs no nothing. I get it off to the side of the road and turn it off it goes into gear fine when car is off. I changed the slave cylinder and the clutch disc today still the same thing I can see the slave cylinder pushing the throw out bearing arm over it just acts like the clutch is not pushing in far enough any help would be appreciated thanks
I looked at the master and seen no leaks outside nor inside. I am going to change the pressure plate today. If that doesn’t fix it then I will change the master cylinder and if that doesn’t help I don’t know what to do next.
Hey did you ever get that fixed cause I have a 1990 honda prelude and it is doing the exact same thing and it had a new clutch and pressure plate and i have tried everything. I am out of ideas.
Chris Miller
Mar 28, 2016 10:49 AM
madeinchina
Transmission & Drivetrain
May 16, 2011 12:38 PM
1993gsrcivic
Dec 2, 2008 10:30 AM
