Radius arm question
Old Dec 24, 2006 | 09:19 AM
I CRX I's Avatar
Default Radius arm question
Could a bent radius arm cause your front wheel to touch fender under breaking?? see im still having this issue where my right front tire touches my fender whenever i brake hard, the only thing i see that could be causing the problem is a bent radius arm, when i took it to a machanic he couldnt find out the problem but the rod is cleeearly bent.
Old Dec 24, 2006 | 09:27 AM
Crx Jimmy's Avatar
Default Re: Radius arm question (I CRX I)
yes, that is most likely the problem
Old Dec 24, 2006 | 09:28 AM
crxnj's Avatar
yes it would..my car had a bent radius rod and the wheel would touch the fender just sitting still...But when i went to replace mine i also found that the crossmember and lca were bent also,because when i got a new radius arm it didnt bolt to the lca or crossmember right..
Kanga
Mar 7, 2016 07:27 AM
be18see1
13
Jul 3, 2010 05:22 AM
vtec25
Dec 30, 2007 04:20 PM
89dohcEF
Oct 11, 2003 08:20 PM
xcathodex
Mar 23, 2003 04:26 PM
