cel code 3. need help quick
ok, after changing my distributor, tps sensor, throttle body, fuel filter, spark plugs, fuel pump, injectors, fuel rail, and fpr to no avail, i finally got my car to throw a cel code.
first off the problem is that my car leans out really bad and loses power above 5000(was 6000rpm but it got worse). it is throwing code 3 for the manifold absolute pressure sensor (map). does this mean that just the sensor is bad, or is there something else that could be causing the sensor to skitz out? would the map sensor cause my problem?
all i want fo christmas is to drive my car.lol so any help will be appreciated. thanks
njandrewg
Sep 9, 2004 07:12 PM
