215/40/17 on a 17x6
Old Dec 24, 2006 | 12:17 AM
sandiegan's Avatar
Default 215/40/17 on a 17x6
Is this safe? I know 215/50/17 would be ideal, but will riding on 215/40/17 cause the sidewall to buckle in a corner or anything?
Old Dec 24, 2006 | 01:44 AM
vtecsi00's Avatar
Default Re: 215/40/17 on a 17x6 (sandiegan)
215/40r17 is better off on a 17x7 but the have the same width
Old Dec 24, 2006 | 06:08 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sandiegan &raquo;</TD></TR><TR><TD CLASS="quote">Is this safe? I know 215/50/17 would be ideal, but will riding on 215/40/17 cause the sidewall to buckle in a corner or anything?</TD></TR></TABLE>
I don't know why you say 215/50-17 would be ideal. It's WAY too big for a 1998 Prelude, assuming that's what you would put it on.
The 1998 Prelude (either version) came from the factory with 205/50-16 tires on 16" wheels. The best tire size for 17" wheels on a 1998 Prelude is either 205/45-17 (0.8 percent larger diameter than stock) or 215/40-17 (1.2 percent smaller diameter than stock). 205/45-17 tires are usually approved for mounting on rims 6.5-7.5 inches wide, and 215/40-17 tires are usually approved for 7.0-8.5 inch rim widths. I would not mount either size on 17x6 rims.
However, are you SURE the rims are 17x6? The smallest commonly available 17" tire size is 205/40-17, and those aren't usually approved for anything narrower than 17x7. The only 17" sizes approved for 17x6 are 205/50-17 and 215/50-17, both of which are MUCH too large in diameter for your car (4.2 and 5.8 percent larger than stock). I would never, ever use a 17x6 rim on a 1998 Prelude for this reason...
Old Dec 24, 2006 | 09:28 AM
sandiegan's Avatar
Default Re: 215/40/17 on a 17x6 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
They are stamped on the back, 17x6 JJ
Who the hell makes a 17x6 rim
Old Dec 24, 2006 | 10:22 AM
vtecsi00's Avatar
stock mazda 3 come's with a 17x6 with a 205/50r17 stock
BB1LOViN
Sep 12, 2007 05:42 AM
leemikemphstn
Sep 6, 2007 07:51 AM
MNsnowdaboy
Aug 11, 2006 07:27 PM
1Tym
Aug 24, 2004 03:39 PM
Doogie Howser
Jun 24, 2002 05:34 AM
