Could someone give me a website selling wire taps
I'm looking for some wire taps but still couldnt find any place online where i could buy a lot of them. I'm looking for the wire taps that clams on two wires which connects them. On ebay they're called molex wire taps and i only saw one ad for it but the size was 12-10 gauge and im looking for some for 16 gauge blue ones.
Im interested in buying alot of these, like 100 or more. could someone give me a link to a site selling these. i just want to buy alot so i dont have to worry about running out on these when i need them.
here's a pic, i hope it works.
You shouldn't be using those pieces of **** anyways... You should be soldering & taping your connections.
Those scotch loks are garbage and the contact point is very minimal. Not at all adequate.
Do it right the first time so you (or someone else) doesn't have to remove it and make the proper connection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">You shouldn't be using those pieces of **** anyways... You should be soldering & taping your connections.
Do it right the first time so you (or someone else) doesn't have to remove it and make the proper connection. </TD></TR></TABLE> I agree
what is it you want to use them for?
If you insist on using them, you can find a distributor here... http://solutions.3m.com/wps/po...ndler.
Again they are not recommended for any kind of connecting in your car for anything that is not temporary.
94
what is it you want to use them for?If you insist on using them, you can find a distributor here... http://solutions.3m.com/wps/po...ndler.
94
thanks for the info.
i already know they're not the best things to use but they're quick and easy. i just use them on my car for accessory crap, like adding on some lights and speakers and other crap that i'll probably get bored of in a year and removing afterwards.
Pikachu
Welding / Fabrication
Apr 30, 2005 09:38 PM
Origin
15
Feb 18, 2004 08:14 AM
