1997 accord engine swap
Old Dec 23, 2006 | 07:04 PM
SlaminRC17's Avatar
Default 1997 accord engine swap
Hello all, I have a 97 accord lx 5sp. I just installed a 95 ex 5spd engine in the car, I used the 97 harness, distributor, fuel injectors. Got everything hooked up, and relized the computer I got with the engine is not the right one at all. The computer that was in my car is a P0J-L11, and the timing cover on the 95 engine I just installed has P0A on it. So I believe I need a P0A computer, but not sure other then that... If anyone can help me, it would be greatly appriciated. Thanx, Kevin
Old Dec 23, 2006 | 07:56 PM
YeuEmMaiMai's Avatar
Default Re: 1997 accord engine swap (SlaminRC17)
should be able to use your ECU with your harness as long as all the sensors plug in
Old Dec 25, 2006 | 01:59 PM
SlaminRC17's Avatar
Default Re: 1997 accord engine swap (YeuEmMaiMai)
Well, if thats the case then how do I find which pins my VTEC solinoid, and oil pressure sensor goto?
Old Dec 26, 2006 | 01:19 PM
hondadude's Avatar
So to Clarify your original post, you are now telling us that you are changing from a non-Vtec engine to a Vtec engine??
the part number on the timing belt cover has nothing to do with ECU part numbers.
Old Dec 26, 2006 | 06:30 PM
SuperSlow's Avatar
you need vtec ecu. or it will run pretty lean after 5k rpms. good luck.
Old Dec 26, 2006 | 11:03 PM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">should be able to use your ECU with your harness as long as all the sensors plug in</TD></TR></TABLE>
you can use the lx ecu but he wont have vtec and will have a CEL for it.
as far as i know for an obd1 motor into and obd2 car...
you need an obd1 conversion harness and you need to repin the dizzy with an obd1 dizzy plug and extend the crank angle sensor wires to that plug as well.
vtec soleniod: Pin A4
vtec pressure switch: Pin D6
Old Dec 28, 2006 | 05:28 PM
SlaminRC17's Avatar
Default Re: 1997 accord engine swap (raceACCORDingly)
Ok, when I installed the the 95 Vtec engine, I used my 97 harnes, so it's got the crank angle sensor there already, and I extended the first O2 sensors wires, and got the hooked up. I just don't know what computer I need for the car...
Old Dec 29, 2006 | 12:46 AM
SuperSlow's Avatar
95 vtec is an obd1 engine. you are putting it in an obd2 car. you may be missing a few sensors if you use an obd2 harness: CEL.
Old Dec 29, 2006 | 09:20 PM
daddysmurff's Avatar
Default Re: 1997 accord engine swap (SuperSlow)
I got an F22B1 can i run an H22 with that harness???
Old Dec 30, 2006 | 11:01 AM
SuperSlow's Avatar
Default Re: 1997 accord engine swap (daddysmurff)
yes
Old Dec 31, 2006 | 01:53 PM
SlaminRC17's Avatar
Ok, no extra sensors on the 97 harness, just need to know which computer I need to get ahols of...
Old Jan 6, 2007 | 09:48 PM
low97accord's Avatar
i am having the same problem. the motor cranks but will not start.
im using the exact same setup he is, obd2 ecu, dizzy and harness and fuel injectors
what exactly would i have to do to get it to start? i notice its not getting any spark and somebody was saying something about a knock sensor or crank sensor or somethin that the obd2 accords have the the obd1 motors DONT have. im confused
Old Jan 7, 2007 | 12:56 PM
SuperSlow's Avatar
Default Re: 1997 accord engine swap (low97accord)
did you set up resistor box for your injectors?
Old Jan 8, 2007 | 03:15 AM
RevengeofTheBees's Avatar
The manual?
Bodie1234
Aug 12, 2018 07:57 AM
Albert 1990
Apr 1, 2015 10:24 AM
Bacondoggy
Jun 20, 2009 08:15 PM
jereme_18
May 16, 2004 03:57 PM
