injectors for d16z6
Old Dec 23, 2006 | 12:50 PM
dro93si's Avatar
Default injectors for d16z6
what kind of injectors would be good for mysetup i got a d16z6 with a ported head and skunk 2 part so i pretty much ahave a built head...and i want injectors what would be the best or better then that the stock ones?
Old Dec 23, 2006 | 01:56 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: injectors for d16z6 (dro93si)
?? what ??
Old Dec 23, 2006 | 02:02 PM
97spooncivic's Avatar
Default Re: injectors for d16z6 (Throwdown)
you really dont need injectors. The injectors on a d series are the same as all b series motors (even type r, someone correct me if im wrong). So even if you have an all-motor d with ported head and skunk 2 "parts," you most likely are still making less than lets say a b18c which uses the injectors you are using right now. You only need new injectors if you are forced induction.
And you should worry about the fuel pump before injectors, and i dont think you need to swap that either.
BxBomber712
Feb 4, 2010 04:45 PM
92ehatch
Feb 8, 2007 04:47 AM
spoonsports12
May 7, 2006 08:42 PM
philafelman
May 11, 2004 04:22 PM
Civic Racer X 7
Aug 9, 2003 02:00 PM
