F/T: 93 civic hatch
The car has some little things wrong with it most of it is exterior. It has a dent on the right lower quater panel below the side molding (not bad at all). It also has a dent on the driver side fender where the corner light is busted also. It has a exhaust leak, and a rip in the driver side seat and carpet.
The motor was just swap into the car about a month ago it is a dx 1.5 16 valve motor. I changed the timming belt, water pump, front and rear seal ,spark plugs and spark plug wires and I think that is pretty much it. The A/C , and the heat work great. The windows work great (has a crack in the windsheild). The car runs perfect, cranks everytime you turn the key.
booja
May 10, 2010 04:41 PM
