Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Bought 07 Si and have a LSD question
Old Dec 23, 2006 | 04:11 AM
Errorich's Avatar
Default Bought 07 Si and have a LSD question
So two days ago I traded in my 06 ex coupe for a 07 si coupe. I've been doing some reading about the performance upgrades for the si and something I read about LSD on wikipedia worries me. Here is the quote from the wiki article.
"The break-in of clutch LSDs is quite critical. Manufacturers give detailed instructions on how to break the diff in. [2] If these are not followed, the LSD may be permanently harmed, in that it may engage and disengage erratically, due to irregularities on and damage to the clutch surfaces. Essentially the LSD must be worked hard to remove manufacturing imperfections, then the now metal-laden oil changed immediately following.
Servicing consists of changing the oil after hard sessions, also to remove metal particles, and eventually replacing the clutches, or the centre. In any case the oil should be changed regularly (as opposed to the open diff, where the oil could be left unchanged for several hundred thousand kilometres)."
Now, does this mean I'm going to have to break in my car hard? I've been researching online and haven't seen anything else that tells me I have to beat around my new car. If I do have to break it in, how should I do this?
Old Dec 23, 2006 | 06:44 AM
Demonis's Avatar
The dealer would have been inclined to inform customers of this, I haven't heard anything about it before you. Wikipedia may be good for a lot of things, but don't expect it to be a Honda expert.
Old Dec 23, 2006 | 07:00 AM
Errorich's Avatar
Default Re: (Demonis)
I'm not expecting it to be. I've just never heard of this before so I wanted to ask around a little.
Old Dec 23, 2006 | 08:02 AM
11sec CR-X's Avatar
Default Re: (Errorich)
I didnt think Honda used clutch type LSDs. Is Helical LSD a clutch type??
Old Dec 23, 2006 | 09:40 AM
Errorich's Avatar
Default Re: (11sec CR-X)
Helical LSDs are mechanical and use a clutch as far as I know. Here is a good picture of a HLSD.
http://www.gkndriveline.com/gk...g.jsp
Old Dec 23, 2006 | 10:39 AM
sdr glenn's Avatar
LSD = Limited Slip Differential
Old Dec 23, 2006 | 10:56 AM
Ross 2.0's Avatar
In a Junkyard near you.
Owners manual > wikipedia
Old Dec 23, 2006 | 01:18 PM
PogKai's Avatar
this LSD as far as I know is non-clutch type, so no worries.
Old Dec 23, 2006 | 01:21 PM
TRE_'s Avatar
Default Re: (Ross 4107)
Helical type LSD's don't require any sort of special break-in or serious maintenance. You have nothing to be worried about.
Old Dec 23, 2006 | 04:40 PM
Errorich's Avatar
Default Re: (TRE_)
Good to hear. My si doesn't come in til Tuesday so I didn't have the manual to look over.
Old Dec 24, 2006 | 12:07 AM
Mach2ek4's Avatar
Helical LSDs are only mechanical and do not use a clutch
Old Dec 24, 2006 | 10:31 AM
11sec CR-X's Avatar
Default Re: (Mach2ek4)
I thought I was right!!! thanx..
Old Dec 24, 2006 | 01:41 PM
Westrock2000's Avatar
In other words they use gears.
Old Dec 24, 2006 | 01:52 PM
Errorich's Avatar
Default Re: (Westrock2000)
Yuuuup. I was pretty gentle with my EX during break in. I'll probably drive my SI harder. It needs to be Tuesday already!
Old Dec 24, 2006 | 04:04 PM
Halcyon819's Avatar
Default Re: Bought 07 Si and have a LSD question (Errorich)
yeah, don't worry too much about it. just drive it normally and u'll break it in fine
dtran002
Dec 8, 2004 08:23 PM
mafay2
Sep 4, 2003 05:36 PM
mafay2
Sep 4, 2003 02:04 PM
SPOON_BeIgHtEeNsEe
May 15, 2002 04:36 PM
KamikazeTypeR
Sep 4, 2001 05:53 AM
