goin hybrid with EG what motor?
I wanna go hybrid but im not sure what motor to go with here are my choices. B18c1, h22a, b18c5,b17a? which one woudl be worth it the most and whichj engine will be the easiest to install? i heard h22a is hard to install in an EG why si that?...thanx
What ever your money allows. If you do have the money for the B18C5, then go for it. However, if you are limited on the budget, you can even go with the LS motor and Turbo it later on!
The first thing that you should probably think about is if you wanna go turbo or NA. That may change the selection of your motor.
