Need help with oem harness on 94 Civic Dx hatch
I have a Kenwood deck installed in my car but i got it that way. When i rewired it for the back speakers i found that the past owners had cut the oem harness. I have everything hooked up except theres a few wires left.
These are the wires i still have unhooked.
Red W/Black Lines
Gray W/White Lines
Blue W/Yellow Lines
Red W/Yellow Lines
Brown W/White Lines
I know one of them is the attena one. My head unit is a Kenwood Kdc-722 and i have 2 wires left. Its the regular Kdc-722 harness. The wires that are left are
Orange W/White Lines
Blue W/white Lines
Please help me because i am rewiring everything back up. Don't want to have any hanging wires.Thank you for your help.
Red W/Black Lines
Gray W/White Lines
Blue W/Yellow Lines
Red W/Yellow Lines
Brown W/White Lines
Blue W/white Lines
Orange I believe is the dimmer, and blue/white is remote.
http://installdr.com/Harnesses/HA-Wiring.pdf
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Okay the link above provides all the info needed. It gives every wires on the car harness. Now are you wondering what wires on the radio harness? The link also tells you what wire color it is typically on the radio harness
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 1994 / Audio
[PRINT THIS PAGE]
Radio 12v white/blue + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- blue/green - gray/black +,- radio harness
RF Speaker +/- red/green - brown/black +,- radio harness
LR Speaker +/- blue/yellow - gray/white +,- radio harness
RR Speaker +/- red/yellow - brown/white +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
[PRINT THIS PAGE]
Power Antenna N/A
No Type:
N/A
Part #: N/A
Notes:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord »</TD></TR><TR><TD CLASS="quote">Orange I believe is the dimmer, and blue/white is remote.
http://installdr.com/Harnesses/HA-Wiring.pdf</TD></TR></TABLE>
Back from the dead... thanks!
orange=illumination
blue=antenna/amp activation
the blues and reds from the cars factory harness are speaker positive wires...
the browns and greys are negatives speaker wires
any unused wires put a piece of E-tape on the end of it as to make sure it won't ground out.
JCracer723
Dec 4, 2003 04:30 PM
