INSTALLING NEW HEAD NEW VALVE ANSWER ASAP
Old Dec 22, 2006 | 05:39 PM
lsegcoupe's Avatar
Default INSTALLING NEW HEAD NEW VALVE ANSWER ASAP
i feel dumb for asking this and i think i already know but i need to comfirm...when measure the valves with my feeder gauge do i measure from the lock nut or do i measure from the bottom of the head on the actual valve opening itself
Old Dec 22, 2006 | 06:21 PM
Miracle's Avatar
Default Re: INSTALLING NEW HEAD NEW VALVE ANSWER ASAP (JDM-SI Sol)
If you are measuring for valve lash, you use the feeler gauge at the contact between the actual valve itself, and its rocker arm/pusher assembly.
NOT A HONDA, BUT YOU GET THE IDEA:
Old Dec 22, 2006 | 08:17 PM
MasterKwan's Avatar
Default Re: INSTALLING NEW HEAD NEW VALVE ANSWER ASAP (Miracle)
I measure between the cam lobe and the follower on my B engines. It's pretty difficult to get between the adjuster and the top of the valve stem (for me anyway).
superfast666
Mar 25, 2008 11:57 AM
Big red89
Dec 18, 2007 10:44 AM
VSBB6
Sep 11, 2005 11:07 AM
BigC-ivic
Oct 22, 2004 02:46 PM
